Better way to run catch can lines?
Old Sep 21, 2012 | 11:40 AM
jordannn93's Avatar
Default Better way to run catch can lines?
Whats the better way to run lines for the catch can and reduce crank case pressure?
1. pcv to catch can to intake manifold.
2. pvc to catch can to crank case breather and cap port on intake manifold.
Old Sep 21, 2012 | 12:24 PM
spectacle's Avatar
Don't use a PCV valve at all and port the two openings on the valvecover to your catch can.
Old Sep 21, 2012 | 12:48 PM
jordannn93's Avatar
So just replace the pcv with a fitting since I have an ap2 valve cover?
So fitting to catch can to crank case breather ?
Old Sep 21, 2012 | 01:32 PM
Phill24's Avatar
Block off pcv also
Ek_Jak
Jun 30, 2017 02:39 PM
GrandMasterKhan
Aug 8, 2013 05:33 PM
s2cho
22
May 23, 2013 08:30 PM
s2konroids
Jan 25, 2011 06:53 PM
