if using a catch can do you keep the pcv valve?
I have heard conflicting opinions on this subject.
When using a catch can. Do you keep the OEM pcv setup? (running from the Pcv port over to the intake manifold)
Depends where your lines are. If none of the ones run from pressurized side of intake to valve cover then not needed. But in part throttle situation you can use the vacuum from intake to suck air out of crank case. Then when you go into boost it closes.
I think all PCV does is keep the flow in one direction. (Positive Crankcase Ventilation)
Since the catch can does not have any reason to push flow back, the PCV doesn't matter.
If you remove it, you simply get more venting.
On the AP2, it's simpler to just swap out the PCV fitting with a hose fitting to make things nice
s2konroids
Jan 25, 2011 06:53 PM
AllStock27
Jul 10, 2005 04:30 PM
