Blue Emanage
Originally Posted by AusS2000,Mar 28 2008, 12:24 AM
The E-manage will replace the ESM and allow you to run bigger injectors. If you're not going mad then it will do what you want.
I ran the E-manage with a Comptech SC at 8lbs and 550cc injectors for a while.
I know and to be honest i wasnt that bothered but everyone i talk to say's they started that way and ended up moving on!! i fancyed the AEM, FIC, ESM, but no one seem's to have them or if they have their's been no posts about them!!!!
And thought about these also:
PLX DM-100 DM100 Wideband o2 HD Display Gauge and SM-AFR .
Any thought's on what the best setup is for me then?
Anyone who has gone through this path will suggest to jump straight to the AEM. They forget the pain along the way.
You want to up boost a bit, that is all. E-manage Blue will let you do this.
Don't know about the PLX.
Thanks again fella
Would you reccomend this for a setup of 9 or 10 psi?
It worked out ok. I was actually running about 8.5lbs.
I'd say that was about the limit of what I'd run. 9lbs, maybe, 10lbs or more and you're starting to get to the reliable limits of injector size compensation and even the MAP sensor.
I ran it for about 10,000Km. I then went to the AEM EMS as part of an upgrade to a LoveFab turbo.
