blue smoke at idle
Old Feb 23, 2008 | 10:32 PM
nMeOnE's Avatar
Default blue smoke at idle
ok lately i've been noticel blue smoke while the car idle but it only happens sometimes after it idle for a while...
One of my buddy said it might be my oil return line which is about 2 feet long and tapped into the front of the oil pan which is causing my seals of my turbo to let oil through at idle...
Old Feb 23, 2008 | 10:40 PM
neeman77's Avatar
you will notice the white smoke when it is coler, especially when you are closer to stoic burn because the byproducts of a good burn is water. It is just water vapour you are seeing, unless you are getting oil in your coolant/boiling over coolant into the overflow I woudlnt be too worried.
Old Feb 24, 2008 | 12:58 AM
Itchy Dick's Avatar
nMeOnE - Have you got a stainless exhaust?
Old Feb 24, 2008 | 08:23 AM
nMeOnE's Avatar
yes i do have a stainless exhasut and i can clearly see water particle around the tip of the ehxuast
Old Feb 24, 2008 | 08:39 AM
JoeyBalls's Avatar
Its normal the Pipes are cold, the exhaust is hot, when the air cools down (from the cold pipes), the air reaches a point in which it can no longer hold the same amount of moisture, (Dewpoint), Warmer air can hold more moisture then cold air, so the warm air is being cooled by the cold pipes, so what you are seeing is the moisture "vaporizing", like your warm breathe in cold air, same thing with airplane engines at high altitude, "Contrails" the moisture from the hot exhaust is vaporizing in the cold air, then freezing
Old Feb 24, 2008 | 08:40 AM
Itchy Dick's Avatar
It's just condensation that collects inside your exhaust then. When you turn the car on it blows it out as it heats up. Basically just steam then. happens to all stainless exhausts when it gets cold.
Old Feb 25, 2008 | 05:30 PM
nMeOnE's Avatar
ok so its not white smoke but its blue smoke and it only happens sometimes at idle...
Old Feb 25, 2008 | 05:45 PM
rob!'s Avatar
how high up is your tap? usually when you have backup like you mentioned in the line i noticed it smokes after you are driving and coming to a stop. But i guess it could be doing it at idle too if your tap isnt too high.
Old Feb 25, 2008 | 06:45 PM
nightcrawler7188's Avatar
i had the same exact thing, except i was NA at the time with only header, exhaust, and test pipe. my car stopped doing it on its own
Old Feb 25, 2008 | 06:50 PM
2QYK4U's Avatar
Blue smoke is a sign of oil getting into the exhaust side of your engine. It can be caused by a number of factors, to include a faulty exhaust valve stem seal or faulty turbo seal.
Xene
Feb 28, 2013 09:55 AM
jonner
Dec 17, 2008 02:27 AM
silverstoneS2
Sep 16, 2008 09:20 PM
nMeOnE
Mar 15, 2008 07:28 PM
