Bolt size for coolant line in block for oil cooler
I'm removing the factory oil cooler and need to find a bolt
for the hole that will be left vacant in the block when i
remove the cooler.
I mean the coolant line that goes to the block.
Does anyone know the thread/pitch/length etc?
Cheers
remove the cooler.
Cheers
I measured 18mm diameter with a 1.0 pitch. It was difficult to locate a bolt/plug this big with a small pitch. I never found one, so I cut the factory fitting short and welded a hex head onto it.
I'd have to double check but I don't think you can't plug that. You need to attach a new hose from the block to the tube that runs across the front of the head.
s2konroids
Aug 13, 2013 11:45 PM
