BOOST GAUGE.
i have a boost/vac gauge and it also sometimes goes into boost. I have the J's lip on my s2k and the holes are opened up, and air gets kinda rammed in there creating a sort of boost like effect on the gauge
Originally Posted by Randizzle88,Sep 29 2008, 07:01 PM
dude your crazy going 125mph on that freeway do you know how many cops are on the 71
i only ran it for about 2 miles.
then exit right off chino hills pkwy.
Originally Posted by passmans2kny,Sep 30 2008, 07:06 AM
u bet some girls like c0ck flavored lollipops, but for real 240 for 3 defi gauges is a steal, why u installed the boost? i do not know
and if i ever go boost im ready.
Originally Posted by TelosHedge,Sep 29 2008, 06:21 PM
theoretically it IS possible to create some positive pressure in an n/a motor IF the car is setup to do so. it is still often a very rare occurrence and a VERY low number - 2psi might be too much to ask for.
i would count on your gauge being broken.
what i want to know is - if you got all your gauges as a package deal, thats fine... but why would you install the boost gauge? sell it to me!
well not now - i dont need broken stuff!
i can guarantee you that its not broken. it run 1-2 psi on my couple runs that day after that i tried doing 1 to 2 vtec hits from 1 and 2nd gear and i cant get it to pass that 0 mark on boost.
Originally Posted by CD7SirAccord,Sep 29 2008, 06:40 PM
The only thing that I can think of is if you are getting your reading electronically from the map sensor. With my AEM, because I live at 5000ft above sealevel, with the car off, the Map sensor reads -3PSI. The only thing that I can think of, is if the guage was calibrated at a higher elevation.
If it's electronic, then I would just assume it's the calibration.
MAybe The Gauge Is trying to tell you to stop being gay and add some boost to make the gauge work the way it was intended to be used!!!! I still cant get over that you have a boost gauge with no boost!!! maybe you should find a deal on a front mount and put that on too !!!! J/K Hope U find out whats wrong !!
