Boost gauge on AfterCooled S/C
Old Feb 14, 2005 | 03:04 PM
Doss's Avatar
Default Boost gauge on AfterCooled S/C
For those of you with an Aftercooled S/C, I was wondering if it would be possible to tap the aftercooler in an area near the throttle body in order to install a boost gauge. Would this work? Would I get the correct readings? Thanks.
Josh
Old Feb 14, 2005 | 03:26 PM
xviper's Avatar
You are better to take a read of the manifold vacuum/pressure. Tapping into the aftercooler will work but it won't give you a "real time" idea of what's going on behind the throttle plate at any given moment. Also, why tap into the aftercooler when it's so much easier to just put a "T" into one of several hoses that run into the intake manifold?
Old Feb 14, 2005 | 03:32 PM
Doss's Avatar
My original post was misleading. The reason why I asked about tapping the after cooler is because I bought a used aftercooler that has already been tapped. I wasn't sure if it was for a boost gauge or maybe for nitrous injection. Instead of just plugging it up I was thinking of using the hole for a boost gauge. But if its not going to read correctly then there is no point.
Actually now that I think of it, it could have been for monitoring intake temps.
Old Feb 14, 2005 | 03:44 PM
xviper's Avatar
Could it possibly be a Vortech aftercooler for an '04 and newer? Those ones have an extra hole in the cooler for the auxiliary injector. Like I said, it will work, but I like to see what's happening in the intake manifold. And when the throttle plate is closed, the measurement will be skewed.
Old Feb 14, 2005 | 03:50 PM
Doss's Avatar
Its a Comptech Aftercooler. I understand what your saying, your right. I may just use it for a intake temp gauge.
Old Feb 14, 2005 | 05:26 PM
xviper's Avatar
If you install some sort of temp gauge, I believe the viewers here would be very interested in seeing pictures of the instrument you use and a report on what those temps are. I know I would be.
Old Feb 14, 2005 | 08:12 PM
AusS2000's Avatar
My chrage pipe (before I got the AC) has a hole tapped in it and a bolt screwed in. I never did find out what the original user used it for.
Personally I'd be looking at water injection via the hole. Especially if you're considering upping boost later on.
Old Feb 15, 2005 | 07:29 AM
Doss's Avatar
Once I get my S/C up and running correctly. I will look into it and see if it's possible. If so I will install the temp gauge. It will be interesting to see the temps since I have the Tech2 front mount radiator for the aftercooler.
Old Feb 15, 2005 | 07:31 AM
Doss's Avatar
You can inject water into the throttle body? I've never heard of this please tell me more.
starrman
Jul 28, 2011 01:19 PM
azride1983
Nov 11, 2008 04:18 PM
jbotstein1
Dec 5, 2005 12:34 PM
Silver S2k4
Apr 6, 2005 09:23 AM
Yellow Streak
Oct 23, 2002 01:30 PM
