How accurate is an Autometer Boost gauge
Old Dec 3, 2005 | 05:36 AM
jbotstein1's Avatar
Default How accurate is an Autometer Boost gauge
Just curious because my boost gauge shows 11 psi at WOT and all I have is the UR gen 2 kit w/ EMS and a Spugen dual ti. Could I really be running that high now that it's cold outside?
Jonathan
Old Dec 3, 2005 | 07:12 AM
xviper's Avatar
Where does the gauge take its reading from? It should be taken somewhere off the intake manifold. If it's too close to the impeller, it may read high.
And does it "zero" itself when there is no boost? This will be an indication of poor calibration.
Does it go to vacuum when you decel? If your gauge is pinned at zero, you will never know and it will be hard to tell if it is calibrated correctly.
Old Dec 3, 2005 | 07:45 AM
John_Z's Avatar
Is it the electric or mech version? Like Xviper said it is best to have a dedicated nipple on the intake manifold for the guage. Don't T off another T. With that said, at 8998 rpm my electric AutoMeter boost guage read 9psi and the actual psi was 8.81psi.
Old Dec 3, 2005 | 05:59 PM
WyattH's Avatar
John Z - That seems pretty accurate? Or is that considered a large margin of error? I would definitely want it reading a tadbit high vs low for safety.
Old Dec 5, 2005 | 09:11 AM
jbotstein1's Avatar
Well, it is t'd off of the intake manifold i think. It just has a clear straw-like tube that is t'd in then straight to the gauge. It does fall back to zero, but there is no vacuum below that on the gauge. Thanks for the replies
Jonathan
Old Dec 5, 2005 | 09:34 AM
xviper's Avatar
If "zero" is also the low end stop point, then you don't really know if the gauge is properly calibrated. For example, if the gauge is reading 5 psi out at zero, then, it will still say "0" and when it begins to move, it may not actually be "0" till you get to "5". So when you see 11, maybe it's only 6. See what I mean? That's the advantage of having a "vacuum" (or negative) range.
Old Dec 5, 2005 | 10:52 AM
f20kills's Avatar
Well, you have an EMS so double check it and compare the two values.
If the EMS shows a big difference, then one of the two is wrong.
Old Dec 5, 2005 | 12:34 PM
jbotstein1's Avatar
Thanks guys. I dont even know how to access my EMS. The cable is accessible but I wouldnt know where to begin once I plugged it into my laptop. XViper, I understand what you mean about the calibration. I plan on upgrading to DEFI gauges but even then, I dont know if they have a negative or vacuum value. I brought up this topic because I didnt think the kit I bought would pass the claimed 7-8 psi. One thing is for sure, I've had it boosted for a few months now and I cant get enough of the acceleration and sounds assosciated with it.
s2konroids
Apr 12, 2010 05:28 PM
s2konroids
Apr 12, 2010 01:13 AM
crav3s2k
Jan 3, 2009 10:36 AM
nMeOnE
Mar 9, 2008 03:47 PM
Yellow Streak
Oct 23, 2002 01:30 PM
