boost loss
Old Dec 16, 2008 | 01:07 PM
kitkat's Avatar
Default boost loss
hi guys,
anyone have any ideas where i should start with regard to my boost loss or running uber rich, the car was professionally tuned a while back (couple of weeks ago) and when out driving hard the car went all of a sudden from zippy to chug chug chug chug etc - it pops and bangs when on throttle but is fine on partial or cruise. I dont have a wideband so is there anything that i can check before going back to the dyno?
Belt slip seems obvious but I have swapped the belt from a dayco 39" to a gates 38.5" already and it makes no difference.
Loose o2 sensor, loose wire on aem?
Any ideas gratefully recieved!
Thanks
Dave
750 rc injectors
10psi pulley
ctsc with ac
30-1052 aem
test pipe
mini krankvents
singe exit 5zigen
hondata 4 bar map sensor
jdm cr!!!! -1mm HG!
red is /was my new figures, blue is the old ap2 pulley.
Old Dec 16, 2008 | 01:14 PM
nightcrawler7188's Avatar
i'm gonna guess your belt snapped..only way you would suddenly lose boost on a supercharger like that. most likely your belt snapped and you're running super super rich cause you're still tuned for 10psi of boost when making 0
maybe you didn't tighten the belt enough the first time, or it was overtightened. with a small pulley like that it should be fairly easy to replace without removing the blower.
Old Dec 16, 2008 | 01:16 PM
Sideways's Avatar
Or pop off a hose or fitting.
Old Dec 16, 2008 | 01:17 PM
yea or a hose could've popped off the aftercooler, spilling all of your intake air. go check it out and let us know!
Old Dec 16, 2008 | 01:18 PM
kitkat's Avatar
belt didnt snap, i just replaced it for the smaller 38.5" one as the old one was at the tensioner limit. and its dark here now but all the pipe work looked in order earlier - ill have to check it all out properly in the light tommorow. its freakin cold too!
Old Dec 17, 2008 | 01:07 AM
kitkat's Avatar
also none of the pipe work is loose
Old Dec 17, 2008 | 01:18 AM
Opposite_Lock's Avatar
are you hitting bumps or something when this happens? or regardless of road conditions, under WOT, this happens?
check your plugs and injectors.
Old Dec 21, 2008 | 03:17 PM
kitkat's Avatar
[QUOTE=Opposite_Lock,Dec 17 2008, 10:18 AM] are you hitting bumps or something when this happens?
Old Dec 21, 2008 | 03:50 PM
Kirpich's Avatar
I had this happen today! But I'm turbo, not SC
Wideband (innovate) was flashing an error code, showing 15.0 regardless of rpm, and as soon as car saw boost in any gear, rpm, speed, it would bog down bad, lose speed, etc.
I made it to a parking lot, unplugged the MAP, plugged it back in (it's hitting the hood lining b/c of Missing Link underneath it), and went to eat. Came out an hour later, all's fine, W/B is not flashing any error code, full boost, no problem. Go figure...
amdaman
Jan 22, 2017 02:03 PM
markforrester99
May 16, 2016 02:13 AM
McFlurry
Nov 23, 2013 03:12 PM
CourageOO7
Oct 1, 2009 11:19 AM
Bibbs
Feb 24, 2007 11:05 AM
