Boost spike
Im pretty sure its the temperature change. What's the temperature normally outside?,all greddy kits tend to boost spike if theres a drastic change in temperature. Try riding the car for a while. Give it like a hour drive let the engine bay get hot n try it again n see if it spikes
The Greddy design is actually better than most out there.
To the OP, try and pull the Vacuum line off going to the wastegate actuator, if it still spikes most likely the actuator needs adjustment. If it does not then it is your boost contoller, most of the standalone controllers are junk. I used several and the only ones that have proven reliable are integrated into a stand alone.
