Boost spike
Old Jan 20, 2013 | 09:37 AM
brownieap1's Avatar
Default Boost spike
Have a full greddy kit.. Suppose to be on 8psi. These past couple days it's been spiking to 15 or so. Anyone know what it might be?
Old Jan 20, 2013 | 11:44 AM
S2KCHRIS305's Avatar
Whats your setup? What exhaust ? Have you done any other mods after you got it tuned?,also has the temperature got any colder in your area?
Old Jan 20, 2013 | 12:01 PM
timg's Avatar
Melted line to your waste gate?
Tim
Old Jan 20, 2013 | 01:20 PM
brownieap1's Avatar
It's the tdo4 18g invidia exhaust.. Yea the tempature has dropped .. It's around 25 to 30 degrees .. I'll check that line to me BOV
Old Jan 20, 2013 | 01:43 PM
Almighty-Si's Avatar
Damaged vacuum line, EBC not compensating for colder temps, or just plain shitty GReddy design
Old Jan 20, 2013 | 02:25 PM
Im pretty sure its the temperature change. What's the temperature normally outside?,all greddy kits tend to boost spike if theres a drastic change in temperature. Try riding the car for a while. Give it like a hour drive let the engine bay get hot n try it again n see if it spikes
Old Jan 20, 2013 | 02:49 PM
sohc_mshue's Avatar
Last one i tuned had serious boost spike issues even with no boost controller. Like 5+ psi spike before settling to wastegate spring level.
Old Jan 20, 2013 | 05:24 PM
brownieap1's Avatar
It still spikes after a 2 hour drive so. I've read up on porting the waste gate or seeing if the flapper is seized or something
Old Jan 22, 2013 | 06:50 PM
dsddcd's Avatar
The Greddy design is actually better than most out there.
To the OP, try and pull the Vacuum line off going to the wastegate actuator, if it still spikes most likely the actuator needs adjustment. If it does not then it is your boost contoller, most of the standalone controllers are junk. I used several and the only ones that have proven reliable are integrated into a stand alone.
Old Jan 24, 2013 | 01:41 PM
Mine isnt ported n no boost spike at all. I get very little spike on cold climates but goes away after my engine bay is fully warmed up
g352s2k
Sep 6, 2009 04:27 PM
blueap2
Aug 26, 2009 06:56 PM
sbrodacz
May 10, 2009 12:49 PM
Josh_With_The_S2K
May 2, 2009 08:16 PM
Spec_Ops2087
May 5, 2007 08:57 AM
