Borgwarner twinscroll internal gate setup
Old Dec 27, 2011 | 11:46 AM
anarchy187's Avatar
Default Borgwarner twinscroll internal gate setup
What do you guys think about this a bottom mount borgwarner 7064 internal gated twinscroll setup? Heres the turbo only problem is you can only get the turbine housing in .92 ar so it might have some serious back pressure problems.
Well lets hear your thoughts!
anarchy187's Avatar
http://www.theboostlab.com/store/pro...252d7064-.html
And heres the turbo!
Old Dec 27, 2011 | 12:00 PM
B5254T4's Avatar
Only 52mm inlet, don´t think it´s big enough to cause back pressure with a .92 turbine.
Think you can go smaller on the turbine if you want.
Old Dec 27, 2011 | 04:19 PM
anarchy187's Avatar
Hmnn I would think it would still be a problem, could you please explain for me?
Old Dec 27, 2011 | 08:31 PM
B5254T4's Avatar
Most people on this forum run .63 or .82 turbine housings, I use a .82 on my 66mm (inlet diameter) turbo, 540whp.
Sounds a bit big to use a .92 turbine on a 52mm turbo, you can go down in size to match the inlet better.
These things need to be tested to be sure since it depends on engine type, turbo, fuel type and much more. Decide your power goal and look at other builds around those numbers. Then you steal their turbo spec.
Cool if you buy the BW, think it will work fine on the S.
Old Dec 28, 2011 | 08:57 AM
camuman's Avatar
on divided setups, bigger is better in most cases. .92 sounds large but on a divided setup it isnt. but i would go bigger on the cold side. thats very small for our motor that breathes very well.
Old Dec 28, 2011 | 09:54 AM
anarchy187's Avatar
The highest I want to go in power is 500hp, but it might be a better idea to go with a bigger compressor.
Old Dec 28, 2011 | 11:46 AM
camuman's Avatar
If u want 500 get a turbo good for 600. Otherwise ur in the top end of the efficiency range of the turbo.
Id get something similar in size to a gt35 at biggest. Maybe a gtx30 would be gangsta for that. Wouldn't need to be divided.
If staying divided go gt35 size at least. 60-63 cold side.
Old Dec 29, 2011 | 08:37 AM
spectacle's Avatar
Originally Posted by anarchy187
TheBoostLab.com owners are personal friends of mine and know their stuff. Whichever turbo you choose, just know they will take care of you
Old Dec 29, 2011 | 03:49 PM
passmans2kny's Avatar
that turbo would dominate for a 500hp set up, I have been very impressed by borg warner turbos and can say they out perform garrett
boostalmighty
Mar 2, 2010 04:15 PM
AndyFloyd
Aug 5, 2009 08:11 PM
S2K_Ownz
Oct 30, 2002 06:12 PM
