broken comptech supercharger belt
Old Dec 7, 2006 | 04:29 PM
Hot.Damn's Avatar
Default broken comptech supercharger belt
hey guys i poped my hood after getting home from work and noticed a rag stuck in my belt that connects to the charger itself. when i wiggled the rag the belt broke i pulled the rag out and the broken belt everything else seems fine including the other belt. I already picked up a new belt at a local autoaid but having a hard time finding info on how to install any help would be sooooo appreciated. is it the same for a vortech?
Thanks,
Ryan
Old Dec 7, 2006 | 04:33 PM
Drkphnx's Avatar
look on the competch website. its in the instructions for the install
Old Dec 7, 2006 | 05:27 PM
elusiv's Avatar
the belt should be large enough so that it'll slip snugly over both the crankshaft pulley and blower pulley.
loosen the tensioner pulley bolt and loop the belt under the crankshaft pulley first. then slip the other end over top of the blower pulley. tighten the belt down with the tensioner pulley and torque the tensioner pulley bolt tight.
Old Dec 7, 2006 | 06:01 PM
Hot.Damn's Avatar
thank you both for your help i really apreciate it.
one more question whats the hazard of the motor running with out that belt?
Old Dec 7, 2006 | 06:15 PM
elusiv's Avatar
none at all, you're essentially running NA with an obstruction (the blower and AC if you hav eone). your car will feel weaker probably, but thats about it. as long as you have a filtered air going through the throttlebody you're safe.
Old Dec 7, 2006 | 06:21 PM
Hot.Damn's Avatar
thats a big relief i dont know how long i went with it torn im only assuming to broke when i wiggled it. again thank you, you are the man! :tu
lvd1102
Jun 4, 2010 08:52 PM
RL1924
Nov 1, 2009 04:23 PM
dustinmallen
Feb 4, 2007 07:26 PM
MB
Dec 21, 2005 05:47 AM
spoiled@21
Nov 28, 2005 04:26 PM
