BRP "Hotside" Supercharger
Originally Posted by nickolas,Mar 14 2006, 02:39 AM
The torque and hp diagram give you the same information. Comparing the area below the hp curve is the same as comparing the area under the torque curve (reason: hp is torque*rpm AND you have rpm for the "X" axis on both diagrams)
Originally Posted by RED MX5
I agree that the averaging method you used yields the approximate area under the power curve, but think about that for a minute. HP is calculated based on torque and revs, and when you average HP over a range of revs you are integrating with revs a second time.
RedMx5, thanks for the additional info. A few of my previous arguments are flawed...
From what I now understand, torque curves show what the forces the engine can produce over the engine's operating range. The horsepower curves show how that torque is effectively put to the wheels due to gearing.
I still have a hard time believing that an engine with a constant 200 lb-ft of torque from idle to redline will push you into your seat with the same force at all engine speeds. Maybe I'm stubborn
Originally Posted by PilotKD,Mar 14 2006, 10:21 AM
Can't wait for this thing to be released. I think we're getting bored.
For you torque lovers.
Pre VTEC
Lovefab [$8,000] ~ 60.3 ft-lb average @ $132.7 per ft-lb
Comptech [$4,000] ~ 15.3 ft-lb average @ $261 per ft-lb
BRP [$6,500] ~ 87.8 ft-lb average @ $74 per ft-lb
Post VTEC
Lovefab [$8,000] ~ 88.8 ft-lb average @ $90.1 per ft-lb
Comptech [$4,000] ~ 40.4 ft-lb average @ $99.0 per ft-lb
BRP [@6,500] ~ 88.4 ft-lb average @ $73.5 per ft-lb
Pre VTEC
Post VTEC
Pre VTEC
Post VTEC
Pre VTEC
Post VTEC
There's some things you can't buy, and some cops you can't bribe
... For everything else there's Comptech
Originally Posted by stitos2k,Mar 14 2006, 12:47 PM
C.A.R.B certified = Priceless
In central Virginia, a C.A.R.B. means nothing more than what you look out for on the Atkins diet.
Originally Posted by slimjim8201,Mar 14 2006, 01:04 PM
Good stuff
The rule that A=F/M is idealized, in that it only considers three factors. In the real world, things are often a bit more complex. LOL, we don't live in a vacuum.
The reason constant torque doesn't produce constant acceleration in the real world is because the *effective* mass (or "load") increases with increasing velocity. Air resistance and friction both eat up more of the force available to produce acceleration as speeds increase.
