BRP "Hotside" Supercharger
Old Feb 10, 2006 | 11:15 AM
  #251
Elistan's Avatar
Originally Posted by Bill @ BRP,Feb 7 2006, 10:13 PM
Mostly correct, but the last part about the "roots" losing boost at high rpm has not been my experience in helping develop BRP supercharger kits. I have done a lot of boost datalogging on both the Miatas and now the S2000 setups and they all start off at lower boost at low rpm and make more boost at high rpm. However, do not confuse higher boost necessarily meaning a higher boost in power. It is true that with a positive displacement supercharger a fairly constant air volume is moved per rev, however this is not the only thing that determines the boost that is measured in the manifold. The more restrictive the engine is downstream, the higher the boost that is seen in the manifold. The volumetric efficiency of the MP series of superchargers is improved from the last generation of the M series.... particularly at higher supercharger rpm and boost levels. The volumetric efficiency actually increases with rpm. For example, at 10psi the MP62 has about an 82% VE at 10000rpm (supercharger). By 16000rpm at 10psi the MP62 has a 95% VE. At the same time, the engine's VE generally decreases with rpm. This means that with a given pulley ratio for the supercharger, the ratio of air trying to exit the supercharger vs. the amount that the engine can consume shifts. This ratio is part of what determines the pressure ratio in the intake manifold and thus the gauge pressure in the intake manifold. Having more boost is actually not a good thing as it really indicates restriction to flow. Of course you can't always have 0psi and huge amounts of flow , but with a given supercharger pulley ratio seeing less boost at the intake manifold after doing things like headwork or exhaust changes generally reflects itself in higher output on the dyno.
On the dyno measuring boost I thought it was pretty interesting how the boost dropped about 1psi when the engine hit VTEC and torque made a nice increase. Basically the boost started at 5psi at low rpm rose to about 6psi right before VTEC, dropped to 5psi after VTEC and then climbed back up to 6psi at the rev limiter. As can be seen on the dyno graph, the torque remained flat and didn't drop off much at high rpm. I think this is also a testament to the efficient S2000 engine. In contrast, on our Miatas the boost generally rises about 3psi from low rpm to redline. The Miata engine of course doesn't breath as well as the S2000 engine at high rpm .
Bill
Bill, I saw a post by Brant that mentioned going to a large throttle body on your test car. He mentioned boost went up by 2psi. By your post, wouldn't that indicate an additional restriction in the airflow path?
Old Feb 10, 2006 | 11:19 AM
  #252
PilotKD's Avatar
Not when restriction was reduced from the throttle side of the blower.
Old Feb 10, 2006 | 12:19 PM
  #253
Nugget's Avatar
This thing sounds sweet, I want to keep an eye out on this.
subscribing
Old Feb 10, 2006 | 01:07 PM
  #254
DeViL's Avatar
315whp @ 6 psi are the current numers from what I've seen. Anyone from BRP want to enlighten us?
Old Feb 10, 2006 | 02:14 PM
  #255
slimjim8201's Avatar
[QUOTE=DeViL,Feb 10 2006, 05:07 PM]315whp @ 6 psi are the current numers from what I've seen.
Old Feb 10, 2006 | 02:50 PM
  #256
Joe @ BRP's Avatar
Graph should be up shortly.
EDIT: It's up now.
Old Feb 10, 2006 | 03:20 PM
  #257
Kremlin's Avatar
AWESOME! 315rwhp and low end torque all on low boost. Incredible! Please for the love of god make it compatible with the MY06...
I wonder what it'll take to get the drivetrain to stand up to it though.
Old Feb 10, 2006 | 06:12 PM
  #258
Nhan's Avatar
I hope they do like a GB when it's all done, hook up the first 10-20 buyers?
Old Feb 10, 2006 | 07:05 PM
  #259
05S2K's Avatar
Wow, 315 rwhp with only 6psi!!! Oh now I'm going to be broke again
Just some food for thought:
Using the industry standard of 15% driveline loss, that's 362 HP at the flywheel!!!
A 3200 lb car (used base S2000 weight of 2800 plus driver and fluids) putting out 315 rwhp could run 12.60's in the QM. How did I get that figure????
Go here and try it for yourself:
Online Dyno
Keep in mind this is just a computer estimate. Either way I think you get the picture. With this kit your S2000 will be sick fast!!!! IMO this is what Honda should have done with the car. Kudos to BR Performance for bringing us a killer supercharger kit that makes usable power.
Old Feb 10, 2006 | 07:16 PM
  #260
PilotKD's Avatar
3200lb? Unless you've got a 400lb driver, the S2000 will not weigh 3200lb. My '04 weighed in at 2700 with a few gallons of gas, less spare and tools in the trunk. With a 175lb driver, I'd estimate around 2950-3000lb depending on AP1 or AP2. I'd be willing to bet this kit putting out 315whp would be good for mid to low 12's. With a gear upgrade, we may have some cracking 11's.
