BRP/SOT Hotside SC Install
Old Jan 28, 2008 | 08:32 AM
  #411
MugenRioS2k's Avatar
It does not mount to the header (I know what you meant just don
Old Jan 28, 2008 | 09:09 AM
  #412
ebeldesign's Avatar
[QUOTE=MugenRioS2k,Jan 28 2008, 09:32 AM] It does not mount to the header (I know what you meant just don
Old Jan 28, 2008 | 09:11 AM
  #413
neeman77's Avatar
haha....I'm so jealous right now, can one of you guys just send me your kit and tell SOT you lost yours? lol...
Old Jan 28, 2008 | 09:20 AM
  #414
WLAURENT's Avatar
Originally Posted by ebeldesign,Jan 28 2008, 10:09 AM
Sorry to add to any confusion with that question. Thanks for the clarification.
For you guys that have installed and used this SC setup, what are your opinions comparing this to the Kraftwerks? These are the two that I am considering and was wondering about the differences/advantages of the SOT.
Thanks for the continued input on this!
Can not really comment on the Kraftwerks setup, but I much prefer my boost/power profile over CTSC and VTSC cars I have driven and ridden in.
Old Jan 28, 2008 | 09:57 AM
  #415
I was originaly looking at the KW setup befor I took the plunge to go with SOT.
Here you go you can come to you own conclusions.
KW data was pulled directly form there website.
I can only compare the low boost KW setup at this time since we do not have a SOT dyno at higher pressures then 6.8lbs of boost at this time.
Old Jan 28, 2008 | 10:04 AM
  #416
ebeldesign's Avatar
That SOT torque curve is unbelievable. Thanks for the comparo.
Old Jan 28, 2008 | 12:05 PM
  #417
JustinC's Avatar
Not trying to say anything bad here, I have seen a roots style torque curve and the one for the SOT seems inaccurate of 200 tq from 1000 RPMS on, you have to build it at some point.
Old Jan 28, 2008 | 12:48 PM
  #418
I extrapolated the TQ down from the lowest data point that has been gathered so far.
Approx 2700. for the SOT
In a real world application the TQ below that would defiantly ramp up because of your ramping of the throttle.
AKA you would not just floor it at 1000 rpms.
However if one was to go 100% TPS at 1000 then the torque would = what I have shown. Not like you would move any where because of clutch slip/ wheel spin however the theoretical TQ values below 3000 do parallel what one would expect to see in the real world if one was able to dump the throttle at 1000rpm.
Did the same thing with the KW populate the power curve down from 2500.
Excel extrapolates the numbers based on its understanding of the pattern the inputted real numbers demonstrate and the boost profiles equations programmed in for centrifugal compressors and positive displacement superchargers.
Old Jan 28, 2008 | 12:54 PM
  #419
Originally Posted by PilotKD,Nov 3 2007, 08:32 PM
you can see where WLAURENT rolled in to the throttel from 2000 up to about 4500
Old Jan 28, 2008 | 12:56 PM
  #420
JustinC's Avatar
Yeah, that seems more like it
