BRP/SOT Hotside SC Install
Old Apr 30, 2008 | 08:08 AM
  #581
neeman77's Avatar
Depending on the altitude, you would be very close to 10 psi with the 142mm crank pulley.
Old Apr 30, 2008 | 08:34 AM
  #582
MugenRioS2k's Avatar
neeman is correct it depends on your altitude, pulley selection and ambient temps. Boost is not the best thing to look at when it comes to a PD supercharger when trying to determine power output.
I am in Huntsville AL
Approx PSI Vs pulley size on a AP2 in huntsville.
(depending on supporting free flowing modifications)
AKA free flowing mods = less boost but more power at the wheels
126=6.5-6.8
135=8
142=9
To prove my point
Say you started with 8 psi making 350whp
Put on a restrictive exhaust and you are now sitting at 10psi but only making 330
Put on a free flowing exhaust and you are now sitting at 7 psi but making 360.
Its how much air you can get the motor to take in burn and pump out that determines power output not specifically the boost pressure.
Old Apr 30, 2008 | 09:11 AM
  #583
GRUNTS2K's Avatar
126=6.5-6.8
135=8
142=9
To prove my point
Very interesting So this only applies to PD superchargers correct?
Old Apr 30, 2008 | 10:53 AM
  #584
Sobe_Death's Avatar
Applies to all engines, NA or FI. It's all about efficiency
Old Apr 30, 2008 | 06:07 PM
  #585
neeman77's Avatar
More specifically for PD supechargers because a certain volume of air compressed into the engine depending on rpm rather than a wastegate. The density of the air (altitude and temperature dependant) will change the boost pressures. The restriction theory applies to all engines and FI setups which is most apparent when looking at turbo selection. A small restrictive turbo will make 280 hp at 10 psi but a larger free flowing will make 350 at 10 psi.
Old Apr 30, 2008 | 08:28 PM
  #586
Sobe_Death's Avatar
I like this thread! Everyone who is seriously looking at this supercharger setup seems to know their stuff
On another note, is the crank pulley going to be a custom unit or does it attach to the stock crank pulley?
Old Apr 30, 2008 | 09:10 PM
  #587
the kit includes a new OEM crank pulley that has been modified to receive the supercharger crank pulley(s).
The new modified OEM Crank pulley modular meaning once you install the modified crank pulley supplied with the kit you will never need to remove it later on if you decided to change the supercharger crank pulley for more boost.
Old May 1, 2008 | 01:05 PM
  #588
vader1's Avatar
Refunadable core charge or do we just keep the old one?
Old May 1, 2008 | 01:11 PM
  #589
No core you keep the original that comes off.
If you know where to get the crank pulley they are only about $70 for a new one.
Makes me wonder why CT/VT charges so much core on there crank pulley.
Old May 2, 2008 | 03:14 PM
  #590
derek14's Avatar
Good stuff Mark! I'm waiting patiently
