CALLING ALL NITROUS GUYS!
Old Mar 4, 2010 | 05:51 PM
Sideways's Avatar
How are you supplying fuel for this shot?
Old Mar 4, 2010 | 05:53 PM
bluemetals2k's Avatar
I thought you didn't need the progressive controllers seeing how I'll be using the aem I thought it would replace it and or do all the same functions?!? Am I incorrect?
Angerman's Avatar
Originally Posted by hariku821,Mar 4 2010, 03:37 PM
If your not running an ems i don think you can go higher than 100. Theirs no way to pull timing. I guess if you have one of the ecus that are hondata compatible maybe?
you can go higher, but I wouldn't
Get a tune.
Old Mar 4, 2010 | 05:56 PM
PsykotiK's Avatar
bigger injectors controlled by the ems, or a wet kit that pulls fuel from the rail
Old Mar 4, 2010 | 06:57 PM
ok....is no one reading the thread or what?!? ZEX DIRECT PORT SETUP comes with everything I need to run a 200 shot including aka the pills you change for more fuel and no2...fuel is supplied by the zex kit...I have a walbro 250lph pump that should be more than sufficient...I am going to use a Aem Ems even for the 100 shot I will NOT run any kind of shot on my car without it ...everything clear now?
Old Mar 4, 2010 | 07:06 PM
freshs2k's Avatar
I think progressive shot is the way to go. Just like the aem water meth kit it sprays progressively easier to tune safer when it kicks on. I don't know what options the aem has for nitrous though.
Old Mar 4, 2010 | 07:10 PM
nsx_bob's Avatar
Im pretty sure the aem cant ramp the nitrous like that. And im pretty sure you can make them work together. If not, just contact AEM it may just be a small change away, kinda like the ivtec and aem change.
Old Mar 4, 2010 | 07:15 PM
ok anybody else about the aem? It will be my first time having 1 so I was under the impression it could handle everything any tuners out there want to input?
Old Mar 4, 2010 | 08:24 PM
PsykotiK's Avatar
kpro.. with nitrous controls, window control, etc etc
Old Mar 6, 2010 | 07:50 AM
anybody else got any input?
