Can't Be... More Bad News
Old Aug 14, 2006 | 05:27 PM
PRS2K's Avatar
Default Can't Be... More Bad News
Well I'm sure most of you have been following me for the last 3 to 4 weeks from my extreme high moments to my extremely low moments. I have just got back in from inside and after a compression test I'm feeling a little under the weather to say the least.
0 - 239
0 - 230
0 - 190 -
0 - 220 -
Cylinders from the front of the car to the back the bottom #'s being the front cylinder. If the 190 was a 220 I wouldn't be posting this but its not.
Method to get the compression test just in case anyone was wondering.
1. I warmed the car up for about 10 minutes
2. I then pulled all the spark plugs which were BLACK!!! The ground straps were black and so was the porcelain on all plugs
3. Pulled the Fuel pump fuse
4. Put gauge in cylinder
5. Had someone hold the gas and clutch down and crank 5 X
Old Aug 14, 2006 | 05:31 PM
geists2k's Avatar
[QUOTE=PRS2K,Aug 14 2006, 08:27 PM] Well I'm sure most of you have been following me for the last 3 to 4 weeks from my extreme high moments to my extremely low moments. I have just got back in from inside and after a compression test I'm feeling a little under the weather to say the least.
0 - 239
0 - 230
0 - 190 -
0 - 220 -
Old Aug 14, 2006 | 05:36 PM
PRS2K's Avatar
Yes I am using the Krank Vents. Picture Below
[/IMG]
Old Aug 14, 2006 | 05:41 PM
Amer's Avatar
Did you do a compression test before going turbo?
Old Aug 14, 2006 | 06:18 PM
geists2k's Avatar
[QUOTE=PRS2K,Aug 14 2006, 08:36 PM] Yes I am using the Krank Vents.
Old Aug 14, 2006 | 08:23 PM
kane.s2k's Avatar
Do leakdown first before assuming different things
Old Aug 15, 2006 | 04:48 AM
PRS2K's Avatar
Originally Posted by geists2k,Aug 14 2006, 06:18 PM
Hmm...
Your running Krankvents and you still managed to pop the dip stick? Are you certain they are installed correctly? I know that boost in the crankcase is one thing that causes the dip stick to pop.
From Fred Perra:
When the car is idling, pull out the dip stick. It should be harder to pull out, and when it does come out, you should hear a psss sound as the vacuum is released. If you don't, then the valves are not hooked up right.
Yes they are installed correctly. If the rings are bad on the piston the crank case can still get pressure and pop a dip stick
Old Aug 15, 2006 | 04:50 AM
PRS2K's Avatar
Yes I did #'s then were
0 - 239
0 - 237
0 - 240
0 - 235
Old Aug 15, 2006 | 08:52 AM
inlinepro1's Avatar
i knew i should've just stayed out of the F/I forum today...Im picking up my inline kit on friday, but now im just plain scared... Any insight on what caused all this?
Old Aug 15, 2006 | 09:43 AM
PRS2K's Avatar
