car bucking
Old Feb 27, 2010 | 11:13 AM
4U2NVmyS2K's Avatar
Well I'm running the BKR8IEX ones. Not sure about the gap ( I've read I don't have to gap those cuz they are iridium...
Old Feb 27, 2010 | 02:05 PM
civicej8's Avatar
yeah, check the gap. did you pre-gap them? they should come pre gapped, but for your setup you might have to gap them less. good luck.
Old Feb 27, 2010 | 03:46 PM
Spoolin's Avatar
What rpm is this bucking happening at? Are you running the Greddy Emanage? They are known for this bucking on occasions. It could also be that youre going lean in that area of bucking.
Old Feb 27, 2010 | 11:28 PM
4U2NVmyS2K's Avatar
Cool
Yea, ok guys, so i finally figured it out.....After swapping my BOV, spark plugs and cleaning my map sensor (just kinda wiping it off), then re-doing everything again, it turns out that on the fuel rail, the banjo connector was leaking fuel (aka, wasnt holding proper pressure and leaking fuel lol) so i got some crush washers, installed, and havent had a problem since. So for those of you that may have had this problem, check for fuel leaks, as this will NOT throw a check engine light up and will cause you to practically want to crash ur car into a wall haha.....But thanks again for all the suggestions guys, i really appreciate it!
Old Feb 28, 2010 | 06:35 AM
s2k aok's Avatar
i'd of thought for sure you would have smelt the fuel leak or seen a puddle when you backed out of your parking space, i didn't think gasoline evaporated that quickly...
Old Feb 28, 2010 | 07:11 AM
chef-j's Avatar
Glad that you figured out.
Verik
Apr 3, 2010 12:06 AM
dopesilverstone
Mar 28, 2009 10:51 AM
penguinap1
Jan 17, 2008 12:07 AM
PersianSTud
Oct 31, 2007 08:32 PM
