Car dies periodically when in neutral
Old Dec 22, 2006 | 09:52 AM
Hitman's Avatar
Smile Car dies periodically when in neutral
Hi all. My car runs great, most of the time: SC'd and tuned with EMS, strong smooth pull under acceleration. However, I've been doing a lot more city-driving these past couple of months and the car would occasionally just die when I'm in neutral (e.g., cruising towards a stop light or down a hill).
If it dies and I am at a decent speed, I would just restart the car while in motion. But there have been a few times when I would have to turn on the hazards in the middle of the road to start the car because I would be at a near-dead stop. Obviously, this is not cool.
So any thoughts as to why this happens? I notice that this happens about once every 2-3 days while driving to work in the morning (weather would be in the 60's). Less often in the evening. I'd appreciate your input before I contact my mechanic.
TIA!
Old Dec 22, 2006 | 10:02 AM
beanolo's Avatar
Possible faulty map sensor?
wildcardtrd's Avatar
Do you have a laptop? Try hooking up to the AEM and monitoring what's going on...I had the same problem on my ITB's...my AFR's were too lean in the 20% to 40% load cells from 1500-3000 rpm, and the EMS couldn't recover from a sudden load drop (shifting to neutral, or waiting too long to downshift)...normal cruising your in completely different fuel and timing cells on the map...up in the 80-90% cells somewhere. When you pop it into neutral, it removes almost all the load off the engine for a few seconds while the rpm's drop....the EMS tracks down very low onto the fuel and timing maps...it's down there where your problem is.
Old Dec 22, 2006 | 10:26 AM
CKit's Avatar
Tune may not be appropriate for the weather.
Also, check your plugs.
Old Dec 23, 2006 | 01:21 PM
spiffey28694's Avatar
I have had the same problem with my 01. Normal driving fine get into town and hit a light it dies. I have checked map sensor time and time again and it be fine. Like ckit said check your plugs. I have noticed in the past when mine starts doing that new set of plugs helps tremendously. Also try checking in your fuel trims in the EMS system. Last time I just called my tuner for a house call and cleared it up and no problems since.
Good luck,
Spiffey
Old Dec 29, 2006 | 02:19 PM
Hitman's Avatar
Thanks everyone. That helps.
Old Dec 29, 2006 | 02:22 PM
Slows2k's Avatar
Moving to FI
S2KVee
Sep 26, 2014 07:08 AM
omg_miiiike
Nov 6, 2010 09:19 AM
nMeOnE
Mar 11, 2008 04:24 AM
Venomous S
Dec 29, 2005 02:34 PM
D-S2K
Jun 15, 2005 09:01 AM
