Car running extremely lean
Old Jun 15, 2007 | 07:53 AM
inlinepro1's Avatar
Originally Posted by batikan,Jun 14 2007, 09:56 PM
That is a relief for me. Thanks for the advice. I am hoping it is not something other than the tape
anyways, you think if i switch the plugs with #1 and #2, it would switch the problem to #2 right?
The wiring on the injector clips would be the first thing to check.
Switching the connector/plug around would really make no difference because either way your still going to end up with a misfire whether it is coming from 1 or 2. Best thing to do i just undo all the tape and check the wiring again. Let me know what happens.
-Chris
Old Jun 15, 2007 | 07:56 AM
inlinepro1's Avatar
Originally Posted by batikan,Jun 14 2007, 09:58 PM
btw, did you have that same running lean issue? also the car is accelerating as if it is like 30hp car. basically not accelerating.
I am not running a A/F gauge in my car so i wouldnt be able to tell you if the car was running lean.
The car accelerated horrible. At first i thought the problem was just at idle because when I first started to drive it seemed to go away but as i got higher up in the RPM range it got very sluggish and sounded horrible.
Old Jun 15, 2007 | 08:58 AM
batikan's Avatar
update. I was planning on switching the #1 and #2 plugs and then unpluging the coils one by one to check if the problem will move from #1 to #2.
anyways, i guess the #2 plug wire was loose so when I tried to unplug it, i came off ( it wasn't the misfiring one though). #1 didn't seem loose but i plugged it to the #2 injector and left the #1 injector unplugged. so if it was a connection problem with the injectors, i should have problem with both #1 and #2. I started the car checked the coil and both #1 and #2 had the same problem. long story short, the problem IS because of a wiring problem on the injector.
Thanks a lot Chris. I'm so happy that it was not a mechanical problem. I'll get the car towed to my mechanic and have him rewire the injectors.
Calamari
Sep 20, 2010 06:53 AM
tommylam16
Jan 3, 2010 02:22 PM
blkatz1
Nov 17, 2006 09:11 AM
Voodoo_S2K
Jul 24, 2005 07:22 AM
demonderrick
Nov 19, 2004 10:56 PM
