car smokes on cold start
Old Nov 2, 2012 | 08:13 PM
andrewv's Avatar
Default car smokes on cold start
Its a new precision turbo JB. I am running a 3an line. It seems like the car only smokes on startup. Its not a whole lot like big clouds but enough to were if I start the car and let it warm up in the garage with the garage door open after a minute or two the garage gets a little smokey. After warming up there is no smoke at all and even after doing a warm start there isnt. It looks like a whitish color maybe possibly blue, but my oil consumption doesnt seem to be changing nor does the coolant level drop. Wondering what it could be? I did do a compression test before installing and it came out perfect. Car has 86k miles, f22.
Old Nov 3, 2012 | 03:43 AM
s2kseven's Avatar
Check the turbo turbine side - could be leaking a little after run. It's hard to check the turbine side unless you unbolt the exhaust pipe.
But what you can do is remove the intake pipe going to the air cleaner to the compressor. Wiggle the turbo shaft up and down and check if there
is a noticeable play.
Also, did you blow the turbo before the new one or this is a new install ?
did you clean the system including the intercooler.
Old Nov 7, 2012 | 09:50 PM
alhanooti's Avatar
i'm running into the same problem, except i also see white smoke at WOT. did you find out what's the problem ?
Old Nov 8, 2012 | 02:22 AM
gettin it's Avatar
Do you have a filter on your turbo? If anything, its probaly only condensation/moistore, especially if it only do it on warm up.
AlexSobe614
Oct 2, 2016 02:56 AM
KaNgArOo
Feb 9, 2015 03:50 PM
DBXFX
Dec 16, 2010 02:04 PM
Shftat9k
Aug 25, 2010 10:01 AM
Little_AP1_S2K
Nov 27, 2009 08:45 AM
