CEL
Old Jun 2, 2009 | 02:24 AM
kylemonster85's Avatar
Default CEL
I just had my CTSC tuned with greddy emanage blue and after a 100 miles the cel light turned on. I checked the code and it was the 2nd 02 sensor. is this normal? can it be fixed to stay off? i had it cleared but turned right back on. what causes this?
Old Jun 2, 2009 | 04:24 AM
devs2k's Avatar
It usually comes on in the absence of a catalytic converter; are you running a test pipe?
Old Jun 2, 2009 | 05:25 AM
stitos2k's Avatar
Sensors do go bad.
I had a sensor go off on my last s2k (it was CT supercharged) because I reversed two small hoses. It would be fine for a couple of days and then kick the cell off, after I got the hoses where they belonged it fixed it.
Before you ask, the only thing I remember was that it was two small hoses near the crank case or head near the front of the engine.
Old Jun 2, 2009 | 08:31 AM
ya its got a test pipe
Old Jun 2, 2009 | 08:52 AM
devs2k's Avatar
test pipe will cause a CEL for secondary o2 sensor; try fitting 2 antifoulers on
you will probably have to drill one for the tip of the sensor to fit
Old Jun 2, 2009 | 08:54 AM
Ya I already have one on there i will try using another
Sexi2k
Nov 30, 2017 04:29 AM
Ap12
Oct 29, 2013 06:57 AM
snoodge
16
Oct 29, 2009 06:33 PM
notyourfriend
Feb 19, 2007 06:54 PM
ttang
Dec 4, 2004 02:29 PM
