Chefs NEW Kraftwerks problem
When I was looking into this I was planning on getting an aftermarket oil cooler just for the rotex figured it would be a better option then running the one that came with the kit. Hope they can overnight the parts to you can get you to your next track day in time.
Sorry to hear the blower is toast. It makes sense that a high temp failure happened with the increase in temperatures at the track. G forces can definitely do crazy things and cause oil starvation too. I wonder if this has happened to any other Kraftwerks S/Ced S2ks at the track? Just saw a local Kraftwerks BRZ run a couple track days without issues but temps were only in the 80's.
Originally Posted by RAIN H8R
The fluid level is supposed to be checked while the car is running. When the car is off the level is MUCH lower. if it was overfilled, perhaps this is why the oil came out of the can, high G loads in the corners could be the problem
Let's try to keep this a fact based discussion and avoid unsupported speculation. The facts that Chief is reporting are oil on the bottom of the can, low oil in the can, metal shavings at the S/C output, noisy S/C, and tight fittings.
Overheating (and boiling over) is a speculative conclusion not supported by facts since there is no observation of oil boiling or coming out of the top of the can nor any temperature readings of the oil.
Other possible causes are a leaking (but tight) fitting, a missing or broken banjo bolt seal, leaking hose and other common causes of leaks not related to temperature.
Originally Posted by beechx1
Let's try to keep this a fact based discussion and avoid unsupported speculation. The facts that Chief is reporting are oil on the bottom of the can, low oil in the can, metal shavings at the S/C output, noisy S/C, and tight fittings. Overheating (and boiling over) is a speculative conclusion not supported by facts since there is no observation of oil boiling or coming out of the top of the can nor any temperature readings of the oil. Other possible causes are a leaking (but tight) fitting, a missing or broken banjo bolt seal, leaking hose and other common causes of leaks not related to temperature.
Originally Posted by hvAlfaWant_S2000
So sorry to hear this Chefs. <img src=/brokenheart.gif' class='bbc_emoticon' alt='
' />' /> All these new KW installs had me second guessing my Vortech set-up. Some seem to be doing OK, others not. Has Billman speculated as to the cause?
Originally Posted by Habitforming
Yes but pin pointing the leak is the key to establishing what happened and why. Is there any oil residue on the top and/or sides of the reservoir? Will the car be going to Bill for him to look at it?
