clock external wastegate?
Old Jul 17, 2009 | 09:36 PM
Deception's Avatar
Default clock external wastegate?
Is it possible to clock an external waste gate like the one in this picture?
the way it sits on the s2k has the barb pointing straight at the valve cover. When the hose is on its sitting against it... only a matter of time before it melts
I have seen those adapter plates that roate the assembly 90 degrees, but that would mess with the dump tube location
Old Jul 18, 2009 | 07:03 AM
m R g S r's Avatar
the vc won't get hot enough to melt the hose...but you can clock the top part by taking off the tiny bolts and rotating the top part. Unless the mounting on the bottom is a v-band, then you're stuck with where the WG exit is....
mongomery1234
Apr 19, 2014 03:52 PM
Mallain123
Jun 19, 2013 08:15 AM
MegaTRon
Jan 23, 2013 06:44 PM
mnr12
May 22, 2010 06:57 AM
Ralleh
Nov 16, 2009 04:34 PM
