Competition Clutch Twin disc
Old Apr 8, 2015 | 10:32 AM
  #61
KEVIN8086's Avatar
Just wait until you add the turbo kit. Talk about vibrations. Both good and annoying. Especially if u go tubular manifold like a sidewinder type. Better brace it pretty good or it will vibrate and crack. I've added multiple braces to mine and it's finally smooth
Old Apr 8, 2015 | 10:34 AM
  #62
KEVIN8086's Avatar
If u keep it to w short right off the head then little to no vibration. But those long runners amplify the motor vibration fairly badly
Old Apr 8, 2015 | 11:06 AM
  #63
deuce_s2k's Avatar
I have a afi sidewinder, lord help me lol.
I tq everything according to specs (honda specs)
Where did u brace it at, can u post up some pix to give me some ideas, thanks
Old Apr 8, 2015 | 12:16 PM
  #64
KEVIN8086's Avatar
U need to find a way to brace it to the motor. Also make a bracket for your downpipe to brace to the block like the OEM design for the headers then add a flex pipe. That should help out a lot. You want to brace from the motor to the collector flange area to help hold up the weight of the manifold and turbo. I was having bad vibration due to the 2 wastegate runners amplifing the motor vibration as well so I braces the wastegate runners to a manifold runner and it helped out a lot. Most of my vibrations are gone. Well bracing just changes the frequency of the vibration. It so much higher now that it's not felt as badly.
Old Apr 8, 2015 | 02:20 PM
  #65
deuce_s2k's Avatar
Thanks.
Old Apr 9, 2015 | 07:11 AM
  #66
KEVIN8086's Avatar
No prob. Text me if you have any questions. 817-773-6881
These cars feel so great at 17-20psi but make sure everything is done right. A proper tune. Fuel pump. Fuel pump direct wiring. Fuel pressure regulator etc etc
Old Apr 9, 2015 | 07:15 AM
  #67
KEVIN8086's Avatar
Be mindful of the trans and I hope u have a rear diff set up
Old Apr 9, 2015 | 09:03 AM
  #68
deuce_s2k's Avatar
Sure will, yea I'm gettin it tune with aem inifinity
Old Apr 9, 2015 | 08:11 PM
  #69
KEVIN8086's Avatar
Let me know how that turns out. I'm curious about how easy it is to tune being a VE based system.
Old Apr 10, 2015 | 10:49 AM
  #70
deuce_s2k's Avatar
Sure will, just gotta put everything on, and find a location for my meth kit. Headaches lol
DFWs2k
17
Feb 2, 2010 01:36 PM
S2000_FUN
Nov 19, 2009 09:08 AM
vteconly
Oct 20, 2008 03:38 PM
jdnissanz
Feb 25, 2006 05:59 AM
skinny finger
Sep 17, 2003 02:56 PM
