Compression ratio = What psi
I have a fully built bottom end with 9.5-1 compression ratio and was wondering what I should get for psi numbers. When I do the compression test I get 180 across the board. What do you guys get when you do the inlinepro 3mm head gasket?
I wasn't to worried just curious. Just wanted to make sure the motor was broken in. Thats all. Thanks
P.S. My new license plates are the same as your user name. VERY NICE!
dont worry so much about the actual numbers, but rather consistency between the cylinders.
the actual number will depend on how many times you crank the car. usually, anything over 15psi difference between cylinders means you have an issue.
2gr84u
Jun 26, 2008 06:38 PM
