Comptech fuel pump failure?
The past two days I have had a issue with my S. It has a Comptech charger. Runs fine with no load just cruising, as soon as you tip the throttle my AEM wideband goes full lean . I already replaced my regulator and the problem got a little better . Know it only does it when it hits Vtec.
Has anyone had problems before with the fuel pump or with the fuel filter? I will be swapping them out tomorrow , just seeing if it is a common problem.
[QUOTE=Twiztid,Oct 12 2005, 05:59 PM]The past two days I have had a issue with my S. It has a Comptech charger. Runs fine with no load just cruising, as soon as you tip the throttle my AEM wideband goes full lean . I already replaced my regulator and the problem got a little better . Know it only does it when it hits Vtec.
Just finished putting a pump in it , no luck . Same problem .
I will swap the filter out tomorrow. And maybe the injectors.
We tune everything with the help from Giles (GilbertG) HolyrollerDyno . Its not tuning ,its lack of fuel .
If all else fails I will be putting in my Sec Fuel rail setup . I have been holding off on this as I have some other products I wanted to test first . I didn't want to show gains with multiple mods. As I already have a dyno sheet showing stock VS sec rail .
Yels2000
May 7, 2007 05:16 AM
