Comptech SC vs Greddy Turbo
I have had the kit on the car since April and have about 15k miles on it. I am very pleased with it, although the 110F temps here in Arizona really effect the efficiency. I am working on getting cooler air into the filter location (where the battery used to be) - should drop my initial air-charge temps by about 50F and result in a 40-50F decrease in the post IC air temps.
I recently replaced the ELF piggy-back (provided by SOT) with a Greddy Ultimate. This has improved boost transition and gives me the ability to pull timing (a real requirement given the before mention temps).
I had a couple of custom size crank pulleys made to play around with the boost levels - but will likely wait until is cools down before I actually test them out. Will also be installing larger injectors at the same time.
Originally Posted by ENTHRALLED,Jul 12 2007, 05:30 PM
thats a lot of driving...I've had my Vortech for 2 years now and only put about 19k miles on it so far.
To your other Q - SOT is working out a distributor plan with a couple companies, then the kit should become available.
moved the fuse box into the fender?
would that give you some room?
Originally Posted by slackfaster,Jul 14 2007, 08:03 PM
do you remember the post in which the guy
The other option I am looking at is to put a NACA duct in the hood to bring cool air into the filter area - and fab up a heat-shield to keep some of the radiated heat off it.
If that does not work I am thinking of actually putting the filter inside the fender area.
