confusion with dbw and turbo'ing
Old Jun 8, 2013 | 10:24 AM
s2konroids's Avatar
Default confusion with dbw and turbo'ing
Ok I'm a bit confused, I'm looking at turbo'ing an my06 with an inline pro stage 2 kit s363 bw turbo.
Ecu wise we can use flashpro is it suffice with 02 feedback etc and boost solenoid? Do dbw s2000s have a wideband as standard?
Does the aem series 2 work out of the box?
I'll be running an in car pc are there pc apps available to show dials etc for flashpro?
Secondly I read about the return line and fully system that it has a limit since I'll be running for 500whp why is a rewired to battery walbro 340 and id 1000s not suffice?
Cheers
Old Jun 8, 2013 | 02:41 PM
liquidgsr's Avatar
The flashpro will work just fine. If you want boost by gear you will need to have hondata add that option by sending it out. Aem has a plug and play harness. I had my ecu modified by hondata for boost by gear, but ended up going with aem shortly after. I have the series 2 with a plug and play harness.
You can run 500hp and below with a returnless system anything higher you will have to convert your system to a return. I went with a full blown full fuel system upgrade. Dual hanger w/FB340s and -10AN feed, -8 AN return, FB fuel filter, and a fuel pressure regulator.
Old Jun 8, 2013 | 02:43 PM
liquidgsr's Avatar
At 16psi max what you probably can run with a stock motor you should reach mid to high 400hp.
Hope that helps.
leo520
Jun 2, 2015 10:00 AM
s2konroids
Jun 8, 2013 10:24 AM
The N/A Way
21
Aug 19, 2010 12:28 AM
EK9MAX
Dec 19, 2008 09:29 PM
Rollinx25
Jun 25, 2008 02:22 PM
