Connecting B16 and ELD question
The ECU itself has all the pins populated on that interface; Hondata will internally connect B16 to a new logic source. The harness in the car does not have the B16 pin populated. You will need to buy a pin and install it in your current harness. Hondata does not provide the required pin (like they do for Civics)
ah so in the harness that particular pinout is empty so I have to run into the factory plug. Gotcha. But as far as the ELD or wideband I can just T tap into that right? I will go to advance auto parts and see if they have a pinout. Thanks for the help.
jordannn93
Sep 29, 2012 09:46 AM
