flashpro boost control
Old Aug 16, 2013 | 04:55 PM
08s2000CRbackinblack's Avatar
Default flashpro boost control
im a little confused here on this subject. my tuner seems to think i have this option already to go.......... dont you have to send your ecu to hondata to get some work done in order for the B16 pin to operate the duty cycle of your boost. or is this already installed. sorry about the stupid question. thanks for any simple answer
Old Aug 16, 2013 | 05:14 PM
99SH's Avatar
Yes you need to mail your ECU to Hondata to wire in the connection.
http://www.hondata.com/fp_s2000_ecu.html
Old Aug 16, 2013 | 05:15 PM
S3X2K's Avatar
If you're talking about boost by gear then yes you are correct.
Old Aug 16, 2013 | 09:50 PM
im not looking for boost by gear, just to control the boost to bring my 10psi wastegate spring up to 15-16 psi. still need to send the ecu out?
Old Aug 17, 2013 | 05:34 AM
wadzii's Avatar
Banned
yep, it has to be sent in. the options will show up in the software even if the ecu hasnt been modded.
Old Aug 17, 2013 | 05:58 AM
miguel329's Avatar
I'm about to wire mine from what I understand its pin b16 where is that? I have a O6 thanks.
Sent from my SPH-L710 using Tapatalk 4
Old Aug 17, 2013 | 08:09 AM
99SH's Avatar
The reference to B16 is at the ECU. Note, the ECU itself has all the pins populated on that interface; Hondata will internally connect B16 to a new logic source. The harness in the car does not have the B16 pin populated. You will need to buy a pin and install it in your current harness. Hondata does not provide the required pin (like they do for Civics)
The B16 pin (it's actually a socket) is part #175265-1 Can be purchased from www.newark.com for $0.27 each
Here's the view of the harness side
Old Aug 17, 2013 | 12:42 PM
miguel329's Avatar
Thanks this helps!
Old Aug 17, 2013 | 10:23 PM
cant wait to get this installed, the down time kinda sucks tho. thanks for the help
FinestS2k
Jan 27, 2017 02:29 PM
GrandMasterKhan
May 28, 2013 08:22 AM
Excalibur
Oct 23, 2012 07:58 PM
liquidgsr
Oct 15, 2012 05:29 AM
Hondata
Apr 6, 2011 06:37 AM
