crankwalk part 2
Old May 20, 2009 | 10:29 AM
  #41
devs2k's Avatar
Originally Posted by TelosHedge,May 20 2009, 02:26 PM
yo devs, did you ever get a new motor? where did you get one from? i'm having trouble locating one.
I haven't touched the car for 8 weeks since I found out I had crankwalk
I just looked in the for sale forums, ebay, and local yards. It's just hard in my case since the easiest thing to do would be to find a complete MY06 motor and just drop it in.
I haven't decided if I am building the motor yet or using a stock motor + HG, and that has been part of the delay.
Old May 20, 2009 | 10:31 AM
  #42
TelosHedge's Avatar
such a shame. i've been checking up on all the engine shops around the country that i know of and nobody has an f22c. i've found a few f20's but they are insanely overpriced. i can only imagine how much harder it must be to find an DBW motor.
Old May 20, 2009 | 10:34 AM
  #43
devs2k's Avatar
pm davgoat and civic5133
those two guys usually buy salvaged S2000s and part out the motor tranny parts; they may have an F22c laying around
so no chance you will build the bottom end?
Old May 20, 2009 | 10:44 AM
  #44
devs2k's Avatar
What clutch are you going with next? I assume you are staying turbo?
Old May 20, 2009 | 03:11 PM
  #45
TelosHedge's Avatar
i will be going with a stock motor again, no question about it. i cannot afford to build another motor. from what i understand there is no way to reinforce this area of the motor. in terms of the compression situation, ive been told that using 9:1 pistons does not help performance over the 3mm head gasket. i'd rather blow the headgasket due to overboosting than blow the motor!
as far as what clutch i'm going to do - i still dont know. i need to do more research. i'd really prefer not to go with a puck type clutch disc but it seems im going to have to.
as for my next setup?? i might just go back to stock. i have no idea.
Old May 20, 2009 | 03:39 PM
  #46
camuman's Avatar
what tq did u make on ur setup?
Old May 20, 2009 | 05:02 PM
  #47
jwa4378's Avatar
I don't think that's right... Its all in the tune. If you have a badass tuner, they will be able to push a built motor WAAAY past a 3mm HG. If you have an OK tuner, they will be about the same. The motor needs pistons designed for that compression, otherwise the "quench factor" is off, and pre-detonation comes in sooner.
If that block is salvagable, parts are parts (and honda's are not cheap, new). If you block is scored, its scored (so machining is necessary, why not just sleeve it?). If its good, you just need some pistons that work with FRM cylinder walls (I think Golden Eagle has some)... Regular low-compression pistons will chew the block up with time.
Sucks man. I am picking my baby up either tomorrow or friday (rod bearings, due to blown HG...).
John
Old May 20, 2009 | 05:36 PM
  #48
Slows2k's Avatar
Price a OEM short block.. You may be surprised what the cost vs value is.
Old May 20, 2009 | 05:55 PM
  #49
TelosHedge's Avatar
i did already. my dealership can get me an AP1 block for 2900 and an AP2 for 3400 - hardly a bargain unfortunately.
in the used market i'd rather not just buy a block either - who knows why it was taken apart in the first place.
i have a couple of leads but im still not sure just yet. i guess i will keep seraching!
and for the guy who asked earlier - i made about 300tq to the wheels.
Old May 20, 2009 | 06:02 PM
  #50
Slows2k's Avatar
The last time I checked the AP1 shortblocks (assembled bottom end) could be had wholesale for under 2500$.. I'm surprised they charge more for the AP2.
The machine shops in my local area can't hold the tolerances Honda can. If I even need to replace the shortblock in car I'll be going OEM Honda.
