Crazy to consider a Supercharger?
no. you need a stand alone ecu. unless you want to destroy your car.
Absolutely! The new CT (and SOS) kits come with a pre-programmed piggyback. A new fuel pump and rising rate fuel pressure regulator is also supplied with the base kits.
Just listen to Junky guys he is correct in every way. I am about to put the CT kit on my car with a little bit smaller pulley with stock injectors and the piggyback with the blackbox to tune it.
What junky said was exactly what my mechanic said, it is very safe to run and reliable. Just listen to the guy and do your research.. supercharging your car is well worth it and very reliable.
I totally disagree. I had the very first installation of a Comptech supercharger into an S2000 in 2001 and I drove that car for 67,000 miles and more than 50 track days without one, I said ONE, issue using the raising rate fuel pressure regulator provided with the kit and an OEM ECU. You will destroy nothing with a proper base kit installation.
ryanvo
Aug 22, 2011 03:01 PM
