Ctsc basic setup question
Old Apr 5, 2013 | 09:50 AM
  #41
s2000Junky's Avatar
Originally Posted by Sylvain2000
180$
But im in canada so ...
Damn that’s expensive! Last set of s2k injectors I had cleaned locally cost me $17 each.
Old Apr 6, 2013 | 07:57 AM
  #42
Sylvain2000's Avatar
Well !!! My life sucks !!!
Just went for a test drive and got on the highway. Problem is still there. My rrfpr is working fine since a see the pressure rising.
Another thing as now got my attention. As i was heading to the highway my girlfriend was talking about a sound she noticed but i could ear it. I did a couple of pulls on tge higway and stopped to crank that rrfpr to see if i could get that afr where it should "without succes".
It is then that she tells me.
-Hey now you can ear it better !!! -
-Well thats sounds to me like the fuel pump ????
So i opened the trunk , put my head in and ... Ya , that is the fuel pump.
So we agreed that the fuel pump was louder then it was on the way to the highway. And as i git back home " couple of miles later " that sound got back to normal " that litle winding "
Now im thinking that fuel pump is diying on me ans the only way i can comfirm that is under load.
I gotta find a way to check that pressure from inside the car
Thats that for now.
If anyone wants to hit me on the back of my head ... Do it ... But write something usefull after ;-)
Old Apr 6, 2013 | 01:15 PM
  #43
\\s2kris//'s Avatar
I had a very similar problem as you. I went through 2 FPR, put my stock cat back on which helped slightly, and did a larger gauge wire to the fuel pump. I eventually swapped the pulley with a 3" pulley,650 injectors, AEM V2, and a front mount a put down 350 to the wheels. Good luck!
Old Apr 6, 2013 | 08:08 PM
  #44
Larger gauge wire was done at the sc installation. As for the cat ... It crossed my mind. If the pump turns out to be fine well that the next step.
Old Apr 7, 2013 | 08:11 AM
  #45
Tested the fuel pressure this morning on the street and it old predsure just fine.
For some reason the afr seem to get leaner and leaner.
Im pissed
Old Apr 7, 2013 | 10:42 AM
  #46
Anyone as an idea if the oem ecu needs to be reset when changing the rrfpr adjustment ???
Old Apr 7, 2013 | 01:00 PM
  #47
JawKnee's Avatar
No.
Old Apr 7, 2013 | 01:27 PM
  #48
s2000Junky's Avatar
Not sure if you mentioned. What kind of fuel pump is it?
New ap1 rrfpr correct?
what is the idle fuel pressure being seen on gauge?
What is the max psi you are seeing on the gauge and pulley size?
Old Apr 7, 2013 | 04:06 PM
  #49
CoolGuy094's Avatar
You are twisting the Allen screw on the RRFPR clockwise to increase fuel pressure in an attempt to get a richer AFR, correct?
Old Apr 7, 2013 | 04:08 PM
  #50
Lol
Yes !!!
I kinda wish i would have answered NO !!! And then everything would work
