Custom Oil Filter Relocation kit
Old Nov 17, 2010 | 05:54 PM
neeman77's Avatar
Anyone know where I can get a new O-ring for my oil filter adaptor? I have an inline kit if it matters. Thanks!
Old Nov 17, 2010 | 06:01 PM
AFs2k's Avatar
http://www.summitracing.com/search/brand/C...s/?autoview=SKU
Old Nov 17, 2010 | 06:05 PM
neeman77's Avatar
wow awesome thanks!
Old Dec 7, 2010 | 06:53 AM
dsddcd's Avatar
Just an FYI the block adapter for the bolt that attaches to the block depending on how the Honda block adapter is cut may be a hair too long. I would check fitment first if the adapter will not tighten down easily remove it and grind down the Canton bolt a few millimeters. After grinding it is essential that you chamfer and smooth the end to prevent tearing the orings on the Canton adapter.
Old Dec 7, 2010 | 07:09 AM
Irishflame27's Avatar
Scott, does the OEM cooler have to be removed to do this?
Old Dec 7, 2010 | 07:40 AM
JDMKID35's Avatar
Banned
Awesome!
Old Dec 7, 2010 | 08:38 AM
dsddcd's Avatar
I have not tested it but the outer diameter and the thread pattern is corret so that it would potential be used on top of the factory heat exchanger.
Old Dec 7, 2010 | 09:26 AM
teamvalorracing's Avatar
does running that much of a larger filter and the appropriate lines cause a pressure drop? or a delay in pressure build on starts?
interesting.
Old Dec 7, 2010 | 09:41 AM
is that "U" section of hose being used to bypass the cooler?
Old Dec 30, 2010 | 03:36 PM
dsddcd's Avatar
Update, a bunch of people asked about the details on the U-bend hose.
Purchased at Advance Auto, should be stocked at all the stores. I have purchased 10 of these at 6 different stores.
