Daily Driven?
Old May 26, 2011 | 10:51 AM
miky360's Avatar
Default Daily Driven?
so im new to Turbo and i know this aint cheap if i want it reliable and i'm well aware of the consequences if i go the cheap and short way. i dont plan on finishing anytime soon so money isnt a issue but i aint a big baller either. i've been doing alot of reading and do you think a set-up like this could be daily driven? running on loost boost of course.
AEM EMS 1052
Clutchmasters Stage 5 6-puck clutch
NGK BKR7E Spark plugs
Science of Speed 3 bar map sensor
InlinePro 3mm Head gasket
InlinePro Oil Filter relocation kit
InlinePro T4 manifold
ARP head studs
BorgWarner T4 S366 w/Polished housing
Tial 44mm Wastegate
Tial Q BOV
Custom 3-inch downpipe
Custom dump tube
Precision 750HP Intercooler
Custom 3-inch Intercooler piping
Fuel Injector Clinic 1000cc fuel injectors
Fullblown Dual pump hanger w/ 2 walbro
255lph fuel pumps
B&R 1 gallon catch can
10AN fittings welded on valve cover
10AN fittings welded on oil pan
Golden Eagle vacuum block
Mishimoto Radiator
Hallman manual boost controller
Modifry ECT
Turbo blanket
HKS Air suction funnel
Password:JDM Radiator stays
Password:JDM Fender washers
MF magnetic drain plug
NRG carbon hood dampers
APR carbon fiber radiator cooling plate
APR carbon fiber spark plug cover
i got it from Honda Tuning and by all means im not trying to copy, but more of a guide.
my main goal is a boosted F22 for daily driving but i want to be able to still rip up the tracks on the time attack.
Old May 26, 2011 | 11:11 AM
S2K-F8's Avatar
I am by no means an expert, but I'm sure most are gonna say skip the 3mm headgasket (stay OEM and uncracked motor if possible)
Scott-
Old May 26, 2011 | 03:56 PM
Dan1987's Avatar
Im SC'd but I believe quite a few of the turbo guys have their turbo oil return tapped just above the oil-pan rather than on it to prevent oil back-up.
Old May 26, 2011 | 04:31 PM
spectacle's Avatar
Where in the hell did you read that a 3mm HG was a good idea? Honda Tuning? I'm canceling my subscription lol
Old May 26, 2011 | 05:04 PM
J-GO's Avatar
It could be daily driven, but with anything that has been modified expect to have some down time. There will be some sort of issue at some point.
Old May 26, 2011 | 08:32 PM
miky360's Avatar
i'm completely new to S2000's im used to FA5s, whats wrong with the 3mmHG?
what do you think i can do to prevent those issues? smaller turbo?
Old May 26, 2011 | 08:34 PM
DFWs2k's Avatar
if you want to be able to "rip up the tracks on the time attack", you are going to need an upgraded differential and tranny at some point
you won't need the manual boost controller or the 3mm headgasket
those are stock heat range spark plugs, so you won't want those
Old May 27, 2011 | 11:38 AM
spectacle's Avatar
do a search for "blown 3mm headgasket" and count how many threads you see
To prevent issues, get a solid tuner who knows the limits of the motor and the fuel used
Old May 28, 2011 | 08:06 AM
nightshift's Avatar
I have a turbo and my experience has been in these areas.
1) Tuning, I has AEM and went to Hondadata, this was better for me a as daily driver.
2) Cooling, I made several changes and it did not get fixed until I had a vented hood.
3) Exhaust manifold, I cracked several and currently have one with a lifetime guarantee.
4) Clutch, tried several and currently with a 6 puck Clutchmasters.
Good luck!
passmans2kny
Aug 18, 2013 02:25 PM
S2SICC
Sep 17, 2012 07:01 AM
Corey Maurer
May 16, 2011 05:19 AM
tranceporter
Jan 13, 2011 07:56 PM
VtecSpool
Feb 28, 2008 12:41 AM
