Do I need High grade bolts?
I would have a new one made. Screw working with this, even it if was counter-sunk. The freaking weld is right next to the hole!
Yea, to even have a shot, you'd need to mill out circular cutout around each hole...
I can't find another flange for this, but I think I may just get the vband cut off and get the downpope welded straight to the 6 bolt flange and have no vband attached to it.
you could fo that, just make sure dp does'nt bend much where bolts need to go in... last down pipe i had on my gsr setup turned hard 90deg angle at flange was almost impossible get 2 of 4 bolts in,,,,
