Does the EMs use the sotck knock sensor?
Old Apr 29, 2008 | 09:13 AM
jbotstein1's Avatar
Default Does the EMs use the sotck knock sensor?
Well... Does it?
TIA
Old Apr 29, 2008 | 09:14 AM
Soul Coughing's Avatar
it reads voltage from it, but you don't need to use it when you setup your tune
Old Apr 29, 2008 | 09:24 AM
jbotstein1's Avatar
thanks for the quick response
Old Apr 29, 2008 | 05:47 PM
timg's Avatar
The AEM EMS uses it. The stock knock sensor is always a nice safegaurd. Some tuners don't like using it, but I like to use it just in case I get bad gas or whatever.
Tim
Old Apr 29, 2008 | 07:09 PM
Asura's Avatar
Monitoring knock volts is always a good idea. With AEM, you can adjust the sensitivity with which voltage changes will cause corresponding changes in accordance with other specific parameters.
Old Apr 29, 2008 | 09:08 PM
CourageOO7's Avatar
Yep...Knock control is good stuff. The software provides very nice visual interpretations of what all measurable metrics are doing at any given time. Good stuff...
lvd1102
May 29, 2009 08:17 PM
ChefJ
Apr 2, 2008 03:36 PM
Spec_Ops2087
Oct 29, 2007 06:38 PM
Spec_Ops2087
Oct 26, 2007 08:41 PM
AndyDoh
Jun 2, 2004 11:41 PM
