does this seem like a fair price?
Just got this estimate, can you guys look it over and tell me what you think? Is it a fair price?
I look forward to reading your response.
K-Pro ecu w/ wiring harness for Honda S2K 1 1,795.00 1,795.00T
Crank sensor 375-PZX-003 1 67.72 67.72T
Crank Wheel 13622-PCX-013 1 9.42 9.42T
TDC Sensor 37510-PZX-003 1 67.72 67.72T
TDC Wheel 14112-PCX-003 1 16.27 16.27T
Valve Cover 12310-PCX-020 1 201.95 201.95T
Drain Plug Washer 94709-14000 1 0.30 0.30T
PCV 17130-PCX-003 1 17.88 17.88T
IAT Sensor 37880-P05-A00 1 15.97 15.97T
Valve Cover Gasket Set 1 27.95 27.95T
NGK Iridium spark plug, heat range #8 4 8.00 32.00T
Brad Penn Racing oil 10w30 / quart 5 6.49 32.45T
S2000 oil filter 1 8.63 8.63T
RC Engineering 650cc Saturated fuel injector 4 98.75 395.00T
Full dyno tune - Hondata K Pro 1 500.00 500.00
S2000 Pro Street manifold T3 44mm gate 1 1,299.00 1,299.00T
Garrett/Precision intercooler with end tanks 750hp 1 559.00 559.00T
TiAl 44mm wastegate (v-band) 1 389.00 389.00T
Tial Q blow off valve 1 229.00 229.00T
Complete oil line kit, stainless steel 1 109.00 109.00T
Custom aluminum intercooler piping with couplers and clamps 1 699.00 699.00T
Custom 3" stainless downpipe with flexpipe 1 549.00 549.00T
Custom stainless dumptube 1 174.99 174.99T
Garrett GT3076R Turbocharger 1 1,229.00 1,229.00T
Custom inlet tube for turbo with air filter 1 175.00 175.00T
Replace exhaust manifold 10 85.00 850.00
Relocate battery, including all materials 5 85.00 425.00
Vacuum lines, fittings, and hardware 1 25.00 25.00T
Oil filter relocation kit 1 250.00 250.00T
Page 1
Description Qty Cost Total
ACT Heavy duty Street clutch, S2000 1 695.00 695.00T
ACT Prolite flywheel -8.6lbs. Honda S2000 1 459.00 459.00T
Inline Pro 3" SS exhaust system, S2000 1 699.00 699.00T
Replace clutch and flywheel 8 85.00 680.00
Honda MTF transmission fluid 2 5.63 11.26T
Install all OEM honda components for K Pro install 4 85.00 340.00
Sales Tax 8.25% 844.76
Page 2
$13,379.27
Page 1
Page 2
$13,379.27
umm are you kidding? 850 to replace the manifold?
Originally Posted by Revenge,Aug 8 2008, 03:37 AM
That looks about right to me, I don't see anything about a 3mm HG and labor so you must not be getting this done. Why not do this now?
