Dogbox interests
Old Oct 29, 2009 | 08:50 PM
  #81
honda9krpm's Avatar
BTW how much heavier is the honda gearbox with the PPG gear in it?
Old Oct 29, 2009 | 09:00 PM
  #82
Spoolin's Avatar
Can you even do the 1-4 dog box and use the stock 5-6? Isn't the dog box 4th gear close to the same ratio as the stock 5th gear?
Old Oct 30, 2009 | 02:33 AM
  #83
honda9krpm's Avatar
My current 5speed gearbox in the s2k has 1-4 dog, 5th and reverse have synchro.
It makes it a bit easier on the street than a full dog system.
Most of the time it should be fine. I read the traffic eg at traffic light or during peak hour and expect when I will need to put the stick back into 1st. I just depress the clutch pedal before I get to move and give the input shaft time to slow down before I put it into 5th.
On rare occasion, when the light suddenly turns green or something that I need to grab first gear urgently (from neutral), I depress the clutch, just rest the stick half way into 5th and use the 5th synchro to slow down the input shaft. Then I chuck it into first. This way I won't damage the 1st dog/dog ring.
5th (or reverse) synchro is cheap compare to the dog ring
I am no gearbox expert/ engineer. However 5th and 6th are next to each other so it is doable unless the 1-4th gears are wider than the stock gears and doesn't allow enough room for the oem 5th and 6th.
The gear ratio can be custom order
Old Oct 30, 2009 | 03:21 AM
  #84
5plusjuan's Avatar
Originally Posted by ERL_S2000,Oct 25 2009, 02:49 PM
Auto
AUTO FTW!!!
Old Oct 30, 2009 | 11:45 AM
  #85
dsddcd's Avatar
Okay, I have a few questions as I am no expert on transmissions
(1) What parts fail in our transmissions?
(2) When the failures occur is it attributed to launching the car or extended loading from hard acceleration?
(3) Has anyone tried, heat treateatment, case hardening……. To the parts that fail?
(4) What about just buying the parts that are prone to failure from a company like PPG for a cheaper alternative?
Old Oct 30, 2009 | 12:28 PM
  #86
boostedf22c's Avatar
From my experiences with this trans, I never broke one launching, I broke 2 2nd gears just rolling into the throttle.
But I'm sure it's just a domino effect. Once you beefed that up, it's on to the next weakest link in the trans
Old Oct 30, 2009 | 12:40 PM
  #87
honda9krpm's Avatar
Yes I lost 2nd in one box and another gearbox was noisy after a launch which broke an axle as well.
The second gear was stripped clean of it's teeth. I have not open up the noisy gearbox to see what's wrong.
Old Nov 3, 2009 | 02:30 PM
  #88
rob!'s Avatar
just keeping this thread up there hoping we can lock something up by mid winter so i can make up my mind on what to do with this car. keep it or sell it and get a supra.
Old Nov 3, 2009 | 03:43 PM
  #89
Sobe_Death's Avatar
Originally Posted by camuman,Oct 29 2009, 04:37 PM
aint that rear mount? can u retrofit that to a conventional mount?
The corvette version is a transaxle, but the ones used in Mustangs, G8, Camaro SS, and Challengers are a standard type transmission. It doesn't negate the need for a new bellhousing or adapter plate though...
Old Nov 3, 2009 | 06:58 PM
  #90
https://www.s2ki.com/forums/index.ph...f=227&t=742997
