Driveshaft Question
Old Apr 13, 2011 | 09:15 AM
Anpaul's Avatar
Default Driveshaft Question
Hey guys,
When replacing the transmission in the S2000 the other day, I found out that the plate which bolts the transmission to the driveshaft was stripped out.
I'm not sure if it happened when I was removing the tranny, or whether it was the last transmission.
Regardless, I was only able to get three bolts (swapped in true grade 8) back in the mount tight and the fourth was only finger tight (wouldn't catch the stripped hole).
The mechanic who was helping me do the install indicated that he didn't think the driveshaft was OEM, but I'm not entirely sure. I don't think that the previous owner installed an aftermarket driveshaft, but wasn't sure if there were even other driveshaft options for the car.
Because of all of this, I'm wondering if the three bolts with a finger tight fourth is strong enough (which I doubt), and if not, how can I go about finding the correct adapter plate to replace it with? Would the part from the dealership be correct, or am I out to lunch and in need of custom fabrication.
The reason I ask is because I'm supposed to be getting the car retuned on Monday, but I'm concerned about putting the car on the dyno as is.
Aidan
Old Apr 13, 2011 | 09:19 AM
Anpaul's Avatar
I just heard back from the previous owner who indicated that the shaft was manufactured by the driveshaft shop.
Old Apr 13, 2011 | 09:43 AM
Torque Obsessed's Avatar
The shop that installed my clutch left one of the bolts out. Took it to the dyno that way, and did plenty of 3rd/4th gear runs afterward... I'm at 326whp though, not sure if you're higher.
Another shop noticed it during an inspection (trying to find my missing 3.3psi and 74whp) and put the last bolt in for me. FYI, they use a seriously long extension (like 2 feet long or more) to tighten those because it forces you to hold everything at the right angle, preventing stripping. An interesting approach.
Old Apr 13, 2011 | 09:46 AM
D1sclaimer's Avatar
The driveshaft is balanced. When the torque on the different bolts are off a lot, the driveshaft will no longer be balanced when spinning.
At least thats how I see it. I could very well be wrong too.
Old Apr 13, 2011 | 11:17 AM
Anpaul's Avatar
I think I'm going to get a machine shop t tap a couple of hellacoils into the plate tomorrow?
According to the DSS, that should be stronger than the plate originally was.
scruffeh
Nov 6, 2015 03:04 AM
arsenal
Jun 4, 2013 11:36 AM
mnr vortx f20c
Dec 18, 2011 08:42 AM
Anpaul
Apr 12, 2011 02:38 PM
krnmike
Aug 3, 2009 03:03 PM
