Dynoed my CTSC'ed 01 S2000
Old Apr 30, 2008 | 01:21 PM
  #91
WindchaserS2K's Avatar
Originally Posted by goldenfri,Apr 30 2008, 12:44 PM
So...
5.5 psi pulley = 2psi with front mount
7psi pulley = 3 psi with front mount
9psi pulley = 8 psi with front mount
...wtf
haha From this thread it seems there is no way to run stock boost with a front mount.
So the more boost you run the less you loose?
Old Apr 30, 2008 | 01:36 PM
  #92
nightcrawler7188's Avatar
that seems to be the trend from every thread i've read and every person i've asked about their setup
Old Apr 30, 2008 | 02:07 PM
  #93
djpeak10's Avatar
That is why you shouldn't run a FMI with a supercharger anyway.
It looks cool, and that is about it.
Old Apr 30, 2008 | 02:26 PM
  #94
I'm not sure if I can agree on that. each have it up side and down size, and I can see quit a bit of weight saving on a FMIC vs a Aftercooler.
Old Apr 30, 2008 | 03:04 PM
  #95
fltsfshr's Avatar
Unless he just wants the bling, an air to air is pretty much worthless under 30mph.
The guy who wrote this lives in Wisconsin. It's only warm there for 2 weeks a year.
He'd be a lot better off building a custom airbox, changing out his fan and putting the filter directly on the charger. Compared to a std vortech intake there's an instant 8 to 10rwhp on the dyno. I'm assuming it helps out a comptech too.
Put an aut plate on it and be done. Free the air let the intercooler do the job.
and that's my opinion.
fltsfshr
Old Apr 30, 2008 | 03:05 PM
  #96
WashabiS2K's Avatar
I'll say it again, the colder intake temps more than make up for the power loss due to boost. Not only does it make up that power, but it does it at a safer psi level.
Old Apr 30, 2008 | 05:08 PM
  #97
TelosHedge's Avatar
Originally Posted by nightcrawler7188,Apr 30 2008, 10:18 AM
how are you measuring IATs? i've never seen an IAT gauge.
the ECU reports IAT's (among other info!) already. i use a scangauge to monitor them, but anything similar will work.
im sure they are not perfectly accurate but they are better than nothing.
Old Apr 30, 2008 | 05:22 PM
  #98
i actually have a scanner, but never stopped to notice what it reads other than CEL codes now that i think about it, i'm sure it does read IAT.
Old Apr 30, 2008 | 05:38 PM
  #99
TelosHedge's Avatar
mine is set to monitoring IAT's, ignition timing, water temp, and TPS. oh yea, it also clears my 'wheres the air pump?!' CEL every day
Old Apr 30, 2008 | 05:45 PM
  #100
gusrock77's Avatar
So...
...wtf
There is no single perfect size intercooler for all boost ranges. At 5psi, this intercooler setup is more than likely too large and causes an efficiency issue.
the SC benifits from the larger FMIC piping when matched with a smaller pulley, injectors and more aggressive tune. with stock psi, the piping may be too big which will be the reasoning for the loss.
as UR stated, their FMIC was based on a higher boost SC. the FMIC piping was meant to work with a higher boost SC.
