Dynoed my CTSC'ed 01 S2000
Old Apr 30, 2008 | 08:11 PM
  #101
TelosHedge's Avatar
what is the piping size on the UR kit anyway?
Old May 1, 2008 | 05:20 AM
  #102
nightcrawler7188's Avatar
2.5"
Old May 1, 2008 | 10:59 AM
  #103
goldenfri's Avatar
Originally Posted by djpeak10,Apr 30 2008, 02:07 PM
That is why you shouldn't run a FMI with a supercharger anyway.
It looks cool, and that is about it.
Old May 1, 2008 | 12:58 PM
  #104
Originally Posted by goldenfri,May 1 2008, 02:59 PM
no, you just need the right piping/intercooler size for the boost you're running. i know more than one person who switched to it from an aftercooler and was more than pleased with the results
i'd go for it later on once i get an EMS/injectors and run high boost.
Old May 11, 2008 | 04:54 PM
  #105
fourstoryfame's Avatar
im having the exact same problem, I have the CT kit w/ a custom FMIC and 8 psi pulley but i only get like 4 psi at 8500 rpm. i thin my belt is tight enough and i dont wasnt to go to tight because i heard you can hurt your bearings. I really dont know what to do. i checked all of my silicone couplers and they are super tight. i want to do a pressure check just to be sure but it doesnt seem real easy. anyone have any input?????
Old May 11, 2008 | 04:58 PM
  #106
dragtek's Avatar
what is the diameter of ur IC piping??
Old May 11, 2008 | 05:01 PM
  #107
2.5"
Old May 12, 2008 | 09:40 AM
  #108
Wiggum's Avatar
I think the loss of pressure through the FMIC is going to be greater than .5 PSI. This may be true if you had an aftercooled kit now, going to a FMIC would only have that cause of a loss, but going from nothing to a FMIC is going to cause a lot more pressure loss.
I'm not fully up to date, but I think most guys when going to a FMIC use a different sized pulley to compensate, which I think even Comptech changed in the AP2 kit....
Your numbers sound like 2PSI with a severe intake blockage to me... get a new pulley on or eliminate the FMIC piping to see how it feels and report back
Old May 12, 2008 | 09:42 AM
  #109
Wiggum's Avatar
You're in the same boat, a 4PSI pressure loss through a FMIC is expected...
On past turbocharged vehicles, switching from a TMIC to a FMIC was AT LEAST a 4 PSI drop...
Old Jun 16, 2008 | 01:42 PM
  #110
gusrock77's Avatar
i thought id liven this up again.
im currently at 13psi on my CTSC and am about to order the UR FMIC.
wish me luck
