eManage
Old Apr 17, 2006 | 08:08 PM
batikan's Avatar
Default eManage
I decided on getting an eManage to use with 9psi Vortech pulley and 650cc injectors. I checked Greddy's Website and there are a lot accessories you can get with it.
I am listing them all:
E-MANAGE (basic unit) piggy-back engine management unit 15500500 $379.00
E-MANAGE INJ. HARNESS for main and sub. inj. control 15900901 $38.50
E-MANAGE IGN. HARNESS for ignition timing control 15900902 $41.80
3.0kg/cm2 PRESS SENSOR secondary MAP sensor 16401301 $120.00
PRESS SENSOR HARNESS use w/ 16401301 16401406 $35.00
E-01 / EMAN. PRESS HARNESS emanage reads e-01 press sensor 15900543 $19.80
KNOCK SENSOR ADAPTOR 1 knock sensor adpt. : 15900903 $18.00
RPM SIGNAL ADAPTOR 1 6 cyl. RPM adpt. (like 350Z, G35) 15900904 $18.00
RPM SIGNAL ADAPTOR 2 4 cyl. RPM adpt. 15900905 $18.00
RPM SIGNAL ADAPTOR 3 RX8 RPM adpt. 15900909 $23.00
IGN. SIGNAL ADAPTOR 1 6. cyl. Ign. adpt. 15900906 $18.00
IGN. SIGNAL ADAPTOR 2 4 cyl. Ign. adpt. (like Evolution) 15900907 $18.00
E-MANAGE SUPPORT TOOL program CD w/ spl. cable 15901001 $139.0
Which of these do I need to get to make it working?? I will also be getting the Boomslang PNP Harness for it
Old Apr 17, 2006 | 08:24 PM
Slows2k's Avatar
Moving to FI. Check out the FI forum FAQ's, all of the important e-mange threads are listed there.
Old Apr 17, 2006 | 08:26 PM
Stratocaster's Avatar
You need these
You should also get a PNP harness so you don't have to cut your existing harness to install it.
I also have all of this that I will be selling, so if you are interested, make me an offer.
Old Apr 17, 2006 | 08:52 PM
batikan's Avatar
Originally Posted by Stratocaster,Apr 17 2006, 11:26 PM
You need these
?? then it is better to get the eManage Ultimate since it costs $650 for the whole kit...
Old Apr 18, 2006 | 04:09 PM
batikan's Avatar
For the description of the boomslang PnP, it says:
Simply plug one side of the harness into your E-Manage Ultimate, and the other side will plug between your ECU harness and ECU. The harness contains the E-Manage Ultimate main, ignition timing, and injector harnesses for instant full tuning capabilities thru your laptop. 100% plug and play with no damage or mess to your factory ECU harness!
does this mean if I get the basic unit, software and cable and the PnP Harness, I'm good to go?? or do I still need to get other stuff with it??
A1ex
Apr 2, 2014 04:30 AM
Sub2K
Sep 26, 2008 07:01 PM
kylemonster85
Aug 30, 2007 11:00 AM
batikan
May 15, 2006 05:27 AM
s2kboost
Aug 20, 2005 09:50 AM
