Emanage boost sensor
Old Sep 3, 2005 | 07:50 AM
spoiled@21's Avatar
Default Emanage boost sensor
I am gonna be using the boost cut eliminator as my voltage clamp and the pressure sensor to tune from but I don't know where to put it. Could some one enlighten me please?
thanks,
Alex
Old Sep 3, 2005 | 08:07 AM
Stratocaster's Avatar
You can install (Mount) it anywhere under your hood. Mine is installed on the driverside fender next to the fuse box. There is a relay mounted there and I just removed the bolt and mounted it with the same bolt. So now both are mounted there (relay and sensor). Next I installed a "T" fitting on the intake manifold vac line that connects the manifold to the fuel regulator and connected the sensor to that.
Old Sep 3, 2005 | 09:33 AM
spoiled@21's Avatar
cool thanks,
ScienceofSpeed
Jan 24, 2011 01:17 PM
dsddcd
Nov 16, 2008 12:04 PM
syellow
Nov 14, 2007 01:11 PM
ChefJ
Mar 24, 2007 09:04 AM
sky-chicken
Apr 6, 2003 09:54 AM
