Emanage experts...
Old Apr 10, 2010 | 07:09 AM
vader1's Avatar
Default Emanage experts...
I just fired up my car after the winter slumber and when the car is warm and has sat for just a couple minutes and you fire it back up it is weak and can die unless you rev it a few times, then it is fine. Once you drive away it is never and issue, just directly following a warm start.
I am not sure if this will correct itself after the stock ECU goes through all of the relearning, but somebody once mentioned something about an anti-stall feature that can be enabled in emanage so it will give it a little extra gas during startup but I don't have a clue how to enable this. Anybody have some advice?
Oh, and if you know how to explain it, please dumb it down like you were explaining it to a total moron. That will help.
Thanks in advance.
Old Apr 10, 2010 | 07:20 AM
myflys2k's Avatar
The stock ecu should learn this. Every time i reset the ecu my car acts the same. Another thing you might want to look into is cleaning the IAC valve. Mine was really dirty, reset the ecu and the car started and idled fine (cold and warm start) but its only been a few days since i did this.
Rupert Huang
Jun 9, 2015 04:42 AM
JSR_AP2
Nov 11, 2013 07:52 PM
gumbys2k
Jan 4, 2011 04:09 PM
pinoyk20
Jun 30, 2008 12:31 PM
2_and
May 24, 2004 06:36 PM
