Emanage injector setting?
Old Jun 11, 2007 | 11:54 AM
ChefJ's Avatar
Default Emanage injector setting?
Is there any reason my tuner would have set the injector value at 730 cc's in the emanage when I have rc 650cc injectors?? Its set as stock 360 injectors 730 correction factor .49. Why would this be and if I change it to 650cc obviously it will effect the map so what should I do??
Old Jun 11, 2007 | 09:32 PM
batikan's Avatar
i thought emanage could onl handle %50 bigger than stock
Old Jul 2, 2007 | 09:42 AM
ChefJ's Avatar
for any ideas. I am setting up an appt. with a different tuner today.
Old Jul 2, 2007 | 01:49 PM
Spec_Ops2087's Avatar
nope, greddy isn't to smart with their own equipment. It can handle any size injector, its just a way for them to get you to buy the ultimate.
Old Jul 2, 2007 | 06:11 PM
AusS2000's Avatar
The Ultimate wasn't even around when that limitation was announced.
To understand the limitation you have to understand how devices like the E-manage and VAFC work. They don't directly control the injectors (Emanage can hold open but not actually close) they intercept and change the voltage level of the MAP signal.
So if your injectors are double the size they simply halve the MAP signal and hope like hell the ratio in the ECU is linear. For small variations like 20 or 30% this is a pretty safe bet. For big variations it isn't and may even make the ECU think there is a problem such as an air blockage. This will throw a code or put the ECU into limp mode.
The 50% rule is just a safe guesstimate. If an injector is 50% larger they decrease the MAP by 33% (think about it) and assume it will be safe.
Old Jul 2, 2007 | 06:13 PM
AusS2000's Avatar
As to the original question, if the car is tuned and running well don't mess with it. And if you're taking it to a tuner just point out the discrepancy to him. He may choose to make the setting more accurate and tune for it or he may discover the reason the previous tuner did it in the first place.
Old Jul 2, 2007 | 06:22 PM
ChefJ's Avatar
I set up an appt. for the 17th with ed senf here in Atlanta. I told them about the issues over the phone and I am sure that they will look into why it may have been done. I am also going to be plugging the vtec crossover points back into the emanage and controlling them from it instead of the ecu's 6000rpm set point.
s2konroids
May 23, 2014 03:38 PM
Trip
Jan 13, 2006 01:55 AM
folex187
Aug 21, 2005 04:16 PM
Salaska
Jun 6, 2004 01:32 PM
honda9krpm
Jan 2, 2004 06:33 PM
