The eManage Magic Setting for Timing Control...
Old Jul 21, 2003 | 09:42 PM
  #91
RT's Avatar
RT
Originally posted by ultimate lurker
Can you change in increments smaller than 1 deg (say 0.1 deg?), or is that the maximum resolution?
UL
Big S why are you concerned about resolution being finer than 1 deg? If you think that's not fine enough then I got even worse news for ya. The emanage doesn't use any input from the crank angle sensor, it just gets the signal from the ECU to fire and puts a delay on passing the info through based on RPM or something. They are only claiming a +/- 1 degree repeatability from firing to firing.
I think the system should work fine for this application (wesmaster's) but it probably won't for whatever you've got brewing that requires a finer res than 1 degree.
Old Jul 21, 2003 | 10:13 PM
  #92
Wesmaster's Avatar
Originally posted by RT
Wes if you guys leave the voltage clamp on you'll have to retune after or waste half your table w/ zeros when you take it off...
Actually, I won't. The Profec e-01 comes with a Greddy Pressure Sensor. This is what we're going to be using as our air flow meter, not the MAP sensor. So, we'll be tuning on true boost levels. The MAP sensor clamping won't affect this at all.
Old Jul 22, 2003 | 06:12 AM
  #93
mbitton's Avatar
Im in the mist of setting up a group buy for the E-manage and all the goodies for it. The prices beat Mohdparts.com...its basically 25% off give or take. I will post the link when I set it up.
Thansk
Mike Bitton
Old Jul 22, 2003 | 06:13 AM
  #94
beroznikmal's Avatar
That would be great.................
Old Jul 22, 2003 | 06:23 AM
  #95
jmonroig's Avatar
Does somebody know the Jump switch setting for the E-Manage?
The ignition timing control for the E-Manage need two setting;
1- The 4-8-C for the rotary switch's(1,2,3)
2- The (7)jump's switch are ????.
Does the E-Manage control ignition advance and retard?
Old Jul 22, 2003 | 07:17 AM
  #96
terry@spool's Avatar
JP1 = 1-2
JP2 = 1-2
JP3 = 2-3
JP4 = 1-2
JP5 = OPEN
JP6 = OPEN
JP7 = OPEN
It can advance and retard timing
Old Jul 22, 2003 | 08:53 AM
  #97
ultimate lurker's Avatar
Ooh, not so good.
I find that you need a minimum resolution of about 0.5 degrees on high performance Hondas (particularly boosted ones) to get optimum results. One of the critical areas comes in the amount of retard you dial in for a given amount of boost. With a minimum 1 deg of resolution (not to mention the slop in the repeatability) you're going to have to run excessively retarded on many apps.
Not a big deal for most people, but its a little sloppy for my tastes.
UL
[QUOTE]Originally posted by RT
[B]
Old Jul 22, 2003 | 08:58 AM
  #98
RT's Avatar
RT
[QUOTE]Originally posted by Wesmaster
[B]
Actually, I won't.
Old Jul 22, 2003 | 10:02 AM
  #99
Wesmaster's Avatar
So is the ECU getting pressure readings from the MAP or the Greddy sensor?
Right now, the ECU is getting pressure readings from the MAP, clamped by the Missing Link and altered by the eManage. After the tuning it will still be getting the reading from the MAP, but it will be altered AND clampled by the eManage.
Old Jul 22, 2003 | 12:54 PM
  #100
RT's Avatar
RT
.... what I'm getting at is in your final config, the emanage although clamping from the ECU, is now getting (seeing) true manifold pressure readings from the MAP sensor where as with your current setup is getting only the clamped (missing link) MAP signal. Do you think the emanage will ignore the fact that it now sees the boost through the MAP signal when it previously didn't? I understand you're tuning the added fuel w/ the Greddy pressure input just not sure of the potential interaction once the emanage sees boost from both sources. What do you think?
